Old 10-12-2011, 08:03 AM   #1
Gavilaso
Drives: Yaris Hatchback 2007
Question Yaris HatchBack 2006/7 Power Cable HELP NEEDED "ASAP"
Hi all from Puerto Rico, I'm completely new to this forums! I have a Yaris HatchBack 2006/7 it was the first Yaris that the Toyota make available. I'm trying to install a HAM Radio on it, I have the antenna installed, the radio is not problem finding a place to put it, but my main problem is finding a way to run the power cable direct to the Battery. I saw the SLICK DIY but i really can't find the grommet that he is talking about on my car.... i don't know if i'm not looking at the right place or what.
So does any one here can point me to another DYI that is compatible with my car? or can someone tell me where i can find a hole to run this cable with out drilling.
just FYI i'm not good with car/mechanic LoL so if it a BABY/DIY for Dummies i will appreciate!!!! LOL
Have a great day!
Gavilaso is offline   Reply With Quote
Old 10-12-2011, 08:14 AM   #2
The Grommet is behind the battery on the engine side and way up under the dash on the inside. If you put your head on the floor, next to the brake pedal, and look up you will see it. The primary cable harness runs through the center of it.
Old 10-12-2011, 08:42 AM   #3
Gavilaso
Thanks for your quick reply!!! I will take a look when i get back at home!!!!!
Old 10-12-2011, 08:13 PM   #4
Gavilaso
I did found the grommet on slick diy, so thanks again!!!!
DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS julienrl DIY / Maintenance / Service 1 08-31-2009 10:06 AM
