Old 10-14-2011, 01:34 AM   #1
Yaris1217
Exclamation 07 Yaris w/ immobiliser won't start - HELP
My yaris was parked in our garage for 3 months, the battery died. We took out the battery and charged it at home with a wall plug. It worked and we were able to drive the car for 3 days without a glitch. So this evening, went to get an oil change and for some reason it wouldn't start. We replaced the battery with a new one and it started it up again. However, it you turn the car off and wait for 30 minutes or so, the car would not start up again unless you take out the negative connection to reset the battery.
also, it seems like the car is having a hard time reving up to 3000 RPM.
Any ideas as to what's wrong? the battery is brand new.
Yaris1217 is offline   Reply With Quote
Old 10-14-2011, 02:41 AM   #2
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
Your car did not come with an immobilizer. Only '08 onwards.
firemachine69 is offline   Reply With Quote
Old 10-14-2011, 09:16 AM   #3
When you try to restart it, does it even try to run, or is it just cranking over and nothing else?
Old 10-14-2011, 10:28 AM   #4
sex
sex's Avatar
Drives: 09 5DR
Is the negative post and cable clean and secure? The 3 month old gas probably went bad
Old 10-14-2011, 10:30 AM   #5
Yaris1217
When we purchased the car, we got the dealeraship to install an immobilizer.
When i turn on the car, theres no noice. The dashboard is on incl the radio.
Thanks
Old 10-14-2011, 10:31 AM   #6
Yaris1217
We filled up the tank right away before we drove so that the old gas is diluted.
Old 10-14-2011, 11:15 AM   #7
it's probably the immobilizer. Aftermarket ones can cause problems.
Old 10-14-2011, 02:12 PM   #8
bronsin
bronsin's Avatar
Yes I am sorry this happened to you but after market things like alarms, remote start cruise control etc frequently cause these problems.
There is no way I would ever have this done to my car.
I would have to believe that if you looked at the things done to install this device you will find the problem.
Old 10-14-2011, 02:17 PM   #9
jekqmb
Local Sh*t Disturber
Drives: 2009 Yaris LB
Is the security light on or flashing when trying to start the car?
Old 10-14-2011, 02:19 PM   #10
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
What kind of immobilizer is it. Is it active, where you have to press a button? Or is it passive where it's got a sensor for when you're in the car?
Old 10-14-2011, 02:21 PM   #11
jekqmb
Could be the start of a bad crank sensor?
Old 10-14-2011, 08:46 PM   #12
Yaris1217
When the car i started, there's no security light flashing.
The immobilizer is a sensor ( a key chain the needs to be beside the key fob) for it to work. I spoke with service and they mentioned that an immobilizer may have a separate battery? anyone heard of this?
Thanks
Old 10-14-2011, 09:27 PM   #13
jekqmb
Thanks
If its your immobolizer your car would start up then die right away, its kind of like an Anti-Theft system from the factory. I think you might have a bad crank sensor, the car is running bad, having problems starting and staying started. I could be wrong though, has the check engine light popped on at all during any of these problems?
Old 10-14-2011, 10:05 PM   #14
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
My brother in law's car's immobilizer craps out on him simetimes, what he needs to do is put the key in, and sit in the driver's seat for a few minutes
battery, immobiliser
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 11:39 AM
Yaris starts then it wont start. wush11 General Yaris / Vitz Discussion 18 01-05-2011 11:53 AM
Let's start a Yaris Club, each member has a specific number decal Yawesh General Yaris / Vitz Discussion 48 04-10-2009 10:49 PM
