Old 01-30-2007, 03:28 PM   #1
Andyfee
Kaminari Yaris
Drives: 2007 Yaris Lift Back
"Help" looking for better brakes for Time Attack Event
Hey Guys and Gals,
Hope all is Well in your world.
Im needing help on finding slotted rotors and ceramic pads for our Yaris
Getting it ready for the first Time Attack Event this year.
Any info would be great were ready to buy but cant find any thing in the States, Any info would help
Thank You To You All
Andyfee is offline   Reply With Quote
Old 01-30-2007, 07:05 PM   #2
spkrman
Drives: 1
shoudlnt be tough at all? I'm sure both are a standard part.
Old 01-31-2007, 11:01 AM   #3
03Z33
03Z33's Avatar
Drives: TCR10
The following compainies offer upgraded brake pads for stock front calipers:
Endless
C-One
TRD
There are probably others, but these are the ones I've looked into. Endless also offer upgraded big brake kits for the front, they both come complete with 4-pot or mini 6-pot front caliper, brackets and two piece rotors (larger diameter).
A company called Fastbrakes are supposedly offering a rear disc brake conversion using OEM parts and a Wilwood caliper. You may look into this, but for time trial it's unlikely you'll need it since the stock drum brakes are lighter than discs and the rear brakes do very little on these cars.
03Z33 is offline   Reply With Quote
Old 01-31-2007, 11:59 PM   #4
Mine are from a Japanese company "e Spec", but they don't seem to have any distributor outside of there.
It makes a nice difference to have big brakes
One thing to keep in mind, I am not sure if it will be the same with those other companies, but the hub part of the disc is thicker than the OEM one, so your wheels will stick out a little more, but it's only maybe 5mm, not really noticeable unless you look closely.
Old 02-01-2007, 05:38 AM   #5
spkrman
Drives: 1
niceinfo
