Old 10-19-2011, 05:58 AM   #1
smpillai11
Drives: Toyota Yari
Yaris 2006 Key Fob
Hi, I have a 2006 Toyota Yaris (Europe). I would like to program a spare key using the procedure in the thread below. However the sticker on my original key has worn off and I am unable to find the type of key required. I tried a key with number CE123, but this does not work.
It would be great if someone can provide me the key type for a similar Yaris.
smpillai11 is offline   Reply With Quote
Old 10-19-2011, 09:15 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Does your car have an OEM alarm or immobiliser?
Old 10-24-2011, 04:29 AM   #3
smpillai11
Drives: Toyota Yari
Has no alarm but has OEM immobiliser
Old 10-24-2011, 06:39 AM   #4
Depending on whether it was made in Japan or France, it can be a couple of different part numbers. If you PM me the VIN of your car, I can run it through the European EPC to determine which is correct for it.
Old 10-27-2011, 08:28 AM   #5
smpillai11
Drives: Toyota Yari
Thanks CTScott. PM sent
Old 10-27-2011, 09:30 AM   #6
The Toyota part number for your transponder key is: 89785-60160
If you have wireless door locks, then the part number for the key with the remote is: 89070-52570
Old 10-27-2011, 03:26 PM   #7
smpillai11
Drives: Toyota Yari
Thanks. I have wireless door locks. Is the part number usually printed on the key fob or inside?
Old 10-27-2011, 04:42 PM   #8
I don't believe that you will find the full part number on or inside of it.
Old 11-02-2011, 10:24 AM   #9
smpillai11
Drives: Toyota Yari
I was looking at buying a second hand key from ebay. What's the best way to source the correct key type?
Old 11-04-2011, 06:24 PM   #10
ZippoYaris
ZippoYaris's Avatar
Drives: 2007 Toyota Yaris 5-Door HB
CE123 is the battery for the fob I think. :)
ZippoYaris is offline   Reply With Quote
2006 Yaris RS Midnightsun New YARIS Purchase Forum 8 06-28-2011 01:18 AM
2010 Yaris Sedan - Need Key Programmed to the Immobilizer vst General Yaris / Vitz Discussion 0 04-17-2011 04:29 PM
