Old 10-20-2011, 02:22 PM   #1
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Fit question
I played it super conservative on my current wheel/tire package:
15x6.5
+40
195/55/15
Lowered on Tein S-Techs
I found a set of wheels that I really like that are:
15x7
+28
No tires
I know the fronts will rub in hard cornering, bumps (my current setup does, too). If I buy this setup, would I be wise to opt for a 195/50/15 tire instead? Will the rears be OK?
Old 10-20-2011, 02:27 PM   #2
When I was running 16X7 +32 in the rear with 195/50/16 rubber, dropped 1.5 inches, the passenger side rubbed on hard dips. A bit of camber rectified that.
Old 10-20-2011, 04:27 PM   #3
33OH
Drives: '08 Yaris
My rears rubbed with passengers on 15x7 +26 with 195/55/15. When I went to 195/50/15 I had no rubbing, but some more ugly fender gap. (DF210's with stock struts.)
I would guess you'd be fine with +28 on 195/55/15's unless you have more than one passenger often.
Old 10-20-2011, 05:56 PM   #4
Thirty-Nine
Good to know ...
Old 10-21-2011, 12:56 AM   #5
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Or you could go with a few other options with an even less chance of rubbing?
195/45/15 or 175/50/15 (my favorite) :P
The amount of passenger that ride with you would play a major factor like 33OH said.
Ummm. 33OH... plz make a thread with your "new" Miata :) pretty please.
EDIT: Thank you 33OH!
Old 10-21-2011, 08:11 AM   #6
33OH
Drives: '08 Yaris
yarisugi - http://microimageonline.com/forums/s...zda-Miata-MX-5.
Old 10-23-2011, 10:39 PM   #7
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
My car is on S-Tech springs and right now I have 15x7's with a +25 offset and 195/50's. A hard enough corner with a bump in it will make the front rub, but it doesn't happen very often. The rear has plenty of room.
Old 10-23-2011, 11:13 PM   #8
hwnstyle21
Drives: White Hatch
15x7
+28
No tires
@Thirty-Nine: What kind of wheels are you looking at?
@Tougeghost: What wheels do you have?
hwnstyle21 is offline   Reply With Quote
Old 10-27-2011, 01:01 AM   #9
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Enkei J-Speeds. (Pictures are in my garage.)
Old 10-27-2011, 10:47 AM   #10
Thirty-Nine
I was looking at a used set of ATS Cups. However, I don't think I'll pick 'em up now.
http://forums.vwvortex.com/showthrea...d&referrerid=0
Old 10-27-2011, 01:16 PM   #11
33OH
Drives: '08 Yaris
^ Haha I was looking at those too, he's just a hop and a skip away from me.
Why does everyone compare the Yaris vs Fit... b_hickman11 General Yaris / Vitz Discussion 71 03-03-2009 09:57 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 08:25 PM
Will honda fit rims fit on a yaris. Meaning are the hubs the same bore? YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 12-24-2008 03:09 PM
question about radio install misfits9095 In Car Entertainment + Electronics (audio / video / alarm) 8 06-06-2007 03:08 PM
question bout aux port SurfBabe900 General Yaris / Vitz Discussion 1 05-28-2007 02:18 PM
