#1 |
![]() Drives: 2007 Toyota Yaris Join Date: Oct 2011
Radio Reception after Car Detailing
Hello everyone,
I am a newbie wondered if I might be so bold as to ask a question? I had my 2007 Yaris detailed last week after some bodywork was done. When I picked it up the saved radio stations were lost (which is fine) but the reception is now scratchy on stations that were previously clear. Any suggestions as to what I should be checking? Many thanks in advance folks - it's appreciated. Lou
Wouldn't surprise me if the detailer took the ant. off to do the work. Ck that.
#3 |
Do you have a sedan or liftback? The sedan's radio is built into the rear window, so if interior detailing was done, the cable that connects to the glass may have been ripped loose. If it is a lift back, like Klink mentioned, check to see that the antenna is still up top.
Also, was the dash taken apart at all?
#4 | |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
rear window. But you probably figured that out. ![]() If you lost the saved radio stations, does that mean that they disconnected the battery? Did the body work require that they remove the battery? What kind of body work was done to your car? Was the radio working properly after the body work and before the detailing, or was the detailing just after they did the body work? If you look at this section from the factory repair manual, you will see the route that the antenna cabling takes. http://www.etimago.com/yaris/repairm...o%20Visual.pdf Just wondering if the body work was done on the areas that the cabling is running through? Perhaps you can give us more information? |
#5 |
Firstly - thank you all for your replies so far.
Secondly - more detail. I have a 4 door sedan. I guess they could have damaged the wire when cleaning the rear window? I will certainly take a look at the wiring to the antenna and see if there is anything obvious wrong. Bodywork involved new bumper (after being rear-ended) and work on a rather large scratch on the front passenger door (Yaris vs. concrete pillar in parking garage) My saved radio stations were no longer saved - this led me to believe they may have disconnected the battery for some reason. I am by no means any kind of expert - so I have no idea why they might disconnect the battery. The bodywork and detail were done at the same place at the same time - so I don't know when the radio station problem begain - I just know it was like that when I picked it up. Thanks again everyone. |
#6 |
Do you have the Integrated Radio or the regular one that comes in the majority of the yaris, take a pic of it. UP close shot as well so we can pull the model number and possibly do a quick Google search and possible trouble shooting techniques.
Check your ground cable to your battery, Maybe they didn't tighten it down ?
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 |
#7 | |
https://www.europasvt.com/UNIVERSAL_...ADIO1_166.html
#8 |
![]() ![]() ![]() Drives: 2007 Yaris Sedan Join Date: Apr 2009
MickZEL; Some countries like the US only use frequencies ending in the odd numbers.
If your radio was designed for one of those countries. All the even ending numbers will not be avilable. Looks like CTScott may have the answer you needed. |
#9 |
Ok, developments:
- Took a look at the antenna in the window - couldn't see anything amiss - Discovered that if I turn the rear window heater off the reception is fine Weird - but solves the problem I guess (unless the rear window needs heating!) So - live with it like it is, or keep investigating?
#10 | |
#11 |
Ok cool - I'll investigate further.
Thanks again for your help. |
#12 |
![]() Drives: 07 Yaris S Sedan Join Date: Jan 2013
please....help!
This is my first post but this exact thing happened to me. My radio is fuzzy as hell and when I turn the defroster off its crystal clear. I'm a dumbshit when it comes to cars, so please excuse me, hopefully ill be learning more soon. Where and what exactly is the C-pillar? Lol and being every part in a car illiterate, how am I going to locate this noise filter? Help the yaris handicapped...
On another note, CTScott, its members like you that made me join this site. There are so many cool projects with great instructions from members like you, and you're incredible knowledge and your willingness to share that knowledge make this such an incredibly awesome tool to me learning about my car! Keep it up and thank you! |
#13 |
Awesome display of technical knowledge and assistance!
The internet moght be good for something after all. My advice? Turn the window defroster on or off to get radio reception and leave it at that.
Synthetic Oil: Its All In Your Head |
#14 | |
#15 |
Thank you, exactly the kind of direction I need! That's what I thought, but id look more stupid assuming something and being wrong than asking. Ill give it a look tomorrow after this snow stops!
| Tags |
| radio, scratchy |
| Car Buying Scams | nemelek | Off-topic / Other Cars / Everything else Discussions | 1 | 09-29-2011 08:01 PM |
| KCALB SIRAY - Photo Scavenger Hunt | KCALB SIRAY | Photo-Video-Media Gallery | 5 | 03-02-2009 10:44 AM |
| Custom Lftback - Photo-Scavenger Hunt | custom Lftback | Photo-Video-Media Gallery | 2 | 03-01-2009 11:12 PM |
| Darb - Photo Scavenger Hunt | Darb | Photo-Video-Media Gallery | 3 | 03-01-2009 09:02 PM |
