Old 10-29-2011, 09:32 PM   #1
RMcG
Drives: Yaris manufactured after 2007
Will switch rated 15 amps/120 volts AC withstand 15 amps DC?
Will a switch that is rated for up to 15 amps/120 volts AC withstand 15 amps DC?
Thanks,
R.
RMcG is offline   Reply With Quote
Old 10-29-2011, 10:32 PM   #2
A switch should be OK. AC only rated relay contacts don't do well with high current DC, but switches are typically fine.
