#1 |
![]() ![]() Drives: yaris hatchback Join Date: Jul 2011
Yaris in SNOW ... how should you drive?
just came from work, it's 11pm in CT... driving a yaris hatch.
oh boy.... it's hard to drive in a 4-6ins of snow. i know, even a 4x4 will have a hard time in snow mix with rain... any tips? specially if your yaris is already shifting sideways... (at 5-15mph!)
Mr. 155 and climbing
Drives: Seriously Modded 07 Sedan Join Date: Jun 2006
It will be trial and error depending on your tires really.
Team Tiamat Racing on Facebook Youtube Channel: Team Tiamat Racing Class record holder in Land Speed @ 154.5mph for 1.5 mile and 145.5mph in the mile in the F (2.016 to 3.014 L), G (1.524 to 2.015 L), and H (1.016 to 1.523 L) classes. |
#3 |
![]() ![]() ![]() Drives: 2010 Carmine Red hatchback Join Date: Mar 2009
Dedicated snow tires will do wonders. I have a set for my Yaris and the difference is unbelievable.
#4 | |
![]() i hate driving uphill/downhill in CT |
#5 |
A manual transmission works wonders. An auto is not as safe. (car doesnt slow down when you let up on the gas as much)
This is my first car with auto trans and antilock brakes. Not a good combination. The car doesnt slow down like a manual and you think the antilocks will stop the car in spite of that. WRONG! My advice is to forget you have antilock brakes and pump the brake pedal carefully as you normally would. That is exactly counter to the manufacturers advice (which is slam on the brakes for all they are worth) |
#6 |
![]() ![]() ![]() Drives: '08 LB, '07 WRX Join Date: Jan 2009
Our yaris is an auto with no abs. The car was fairly scary on the stock all season tires in ANY amount of snow. We put ContiExtreme Winter tires on it for last season, and that made a HUGE difference. While its still no 4x4, the yaris with snow tires is slightly better in deep snow than my AWD Subaru on brand new all-seasons. I have ABS on my car, and the yaris can definitely out stop me. I can still take it in a straight line from a dead stop though ;)
#7 |
i generally avoid the brakes as much as possible and just coast alot. momentum avoids getting stuck :) Brake slowly and lightly as much as you can.
#8 |
![]() ![]() ![]() Drives: 2009 5-Door Liftback Join Date: Jun 2011
I agree with this 100 percent, and I've likewise discovered that it's better to just pump the brakes if you find yourself in a slide. This is the first car I've ever driven that has ABS, and I fail to see how it's safer.
#9 |
ヴィッツ ドライバー
Drives: 2006 3d 1.0 Linea Sol Join Date: Aug 2007
I should probably attach a disclaimer of sorts to this post, but hey, I'm just telling you what works for me.
I find myself reaching for the e-brake (handbrake) when I need to stop when the road is covered with snow/slush. This is especially true when I need to stop suddenly. The ABS system on the Yaris sucks for braking distance (but is great for retaining manouverability though). I mean, when applying the brakes in slippery conditions, I have enough time to read a magazine while the Yaris very slowly loses speed. So when you know you have to stop, there speed is low enough not to lose control of the car and you're up for it, try the e-brake. |
#10 |
Oh, I forgot to add....I once read that if you find yourself in a slide, steer in the direction of the slide, and you'll regain control. It sounds counterintuitive, but it really works. This applies to any car, not just the Yaris. And, of course, never panic.
#11 |
good advice. this is called countersteering. just DO NOT mash the brakes when you start to slide, as previously noted, the rear end will step out and you will spin.
#12 |
My ECHO on the stock tire was a nightmare in snow. Very twitchy, little traction. They were the Potenza 92s. My Yaris with the exact same tires is quite good.
![]() My advice if you find your car not nice to drive in snow is do a little research on Tire Rack and find a better set of tires.
#13 |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
Snow tires. And do everything more slowly than normal. No sudden pushes at any of the pedals, no sudden tweaks to the steering wheel. You're trying not to break anything free from the traction.
#14 | |
...or Vegas for short
Drives: 2010 Toyota Yaris 3door LB Join Date: Jul 2010
#15 |
![]() Drives: 2007 Yaris Sedan Join Date: Nov 2008
Yup....snow tires....as the stock tires were and are just that...minimal. Driving an '07 and got Dunlop Graspic 2's year one...and what an amazing difference...so in spring thru fall the stock tires and ..well.....this week on go the snows. Up here in N. Wisconsin i would rather feel save and get safely where I need to be, without doing hail Mary's the whole drive....Spent a bit for the tires, (actually the same amount as my deductible had I a mishap and needed body work) but it was a perfect investment. The wife said she feels like there is more bite into the snow than even our 4x4 Blazer. Now that says something.
The deeper tread, and more pronounced siping and of course the softer tire material make for a very enjoyable winter. Regular tires get harder the colder it gets. Standard M&S (mud and snow) tires just can't do all they claim to do. Last thing here....if you tend to drive alone? I put a sandbag in the foot compartment of the passenger area and that makes a very light car get even more traction. The engine over the front wheel drive can only do so much. And of course....super tires or not...the lowness to the ground will get you "hung up" in plowed areas like driveways.....I am surprised my lower front wind guard is still there after plowing my way thru deep snows. Invest in safety...get snows too...unless you live in the sunbelt where you only have freak storm needs. Just my thoughts.......... |
#16 |
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
under 40 degree tires(thanks BARBER) on all 4 corners make for one hell of a good time if you like to play in the snow. Saturday's snow had me driving on unplowed roads with little to no problems......
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
#17 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
If your Yaris has ABS, park it and wait for the snow to melt.
My Echo was great in the snow. I would go damn near anywhere and would stopped pretty darn well. The Yaris goes OK....it just won't stop. |
#18 |
Drives: yaris Join Date: Jan 2011
snow tires make all the difference
a full on winter tire with the mountain snowflake symbol is the only way to go in winter. I got Michelin X Ice Xi2 and they truly do allow the Yaris to climb steep snow covered hills, and make corners safely, unbelievably well. it went from 'I never want to drive this in the snow' to 'this car is unstoppable in snow' The X Ice also doesn't howl on the highway, like other studless snows. It is the best snow tire for what I do. short weekday commutes on steep drumlins, and long trips up the interstate on weekends. any current studless snow tire will be like night and day on the Yaris. if you want MAX possible grip, get something with chunky blocks like the original Blizzak LM50. If you want excellent snow and ice grip but less howl on highway, get the Michelin X Ice or the newer Blizzak with a similar tread like WS60 or WS70 *if you want to stick with an M+S tire that does OK in snow, Michelin makes the best M+S tire hands down. They actually last long in summer and have real grip in winter to some extent. |
| what snow tires good for Yaris Hatchback. | opor24 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 12-28-2009 12:53 AM |
| HELP!? HORRIBLE drive home during first REAL Snow in Michigan, | paulyd0021 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 12-11-2009 08:07 PM |
| Floor Mats 4 Aussie Yaris (right hand drive) wanted! | YesHapiness | Cosmetic Modifications (Exterior/Interior) | 6 | 02-12-2007 07:29 AM |
