#1 |
Corporate Slave
Drives: 2010 Yaris YX aka "Cutie" Join Date: Oct 2011
RPM to Speed Ratio
Mga kayaris, tama ba or same ba sa inyo na running at approx 140-150kmh eh nasa 4000rpm natin medyo mataas at galit na galit engine right ganito rin ba sa inyo???
I've had a different experience kasi sa Expedition Ford ng office which goes to about 180kmh at 3200rpm or 3500rpm which could make sense dahil sa diperensya ng engine type and number of cylinders pero ganito rin ba Yaris ninyo 140-150kmh at 4000rpm na??
Si Vis Pacem Parabellum CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to. Keep your ride rockin and rollin |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan 2010 "shadow" Join Date: Mar 2010
#3 |
Corporate Slave
@ syntax, my Yaris has clocked about 38K so medyo ok pa spark plugs yung injector cleaner magkatalo saka anong octane gamit ninyo 91 or 95? naka 91 kasi ako?
#4 |
@ charlie, medyo ok pa nga ang spark plugs mo pero malapit na palitan yan, octane rating? well medyo malalim na katanungan yan at maraming kuro kuro tungkol sa octane rating, sa akin at maybe sa ibang kayaris, we follow the manufacturer recommendations which is 91, kapag binuksan mo rin takip para sa fuel tank mo, makikita morin dun 91... hth
#5 |
Corporate Slave
@ syntax, yeah that's what I follow as well and a reco of a friend in Toyota na rin na our engines are a bit on the small side and that the 95 is going to be too hot for it.
#6 |
Corporate Slave
Q: naka iridium na ba itong Yaris natin from the production line?
#7 | |
![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Apr 2009
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter) Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way If everything seems under control, you`re just not going fast enough...
#8 |
#9 |
Corporate Slave
Does anybody here have an iridium plug, para masilip muna ang performance upgrade bago magpapalit ng iridium
#10 |
tol merong naka iridium d2 and according to him mas ok ang response.. sad to say ndi na sya active sa site...
#11 |
Corporate Slave
hmmm sounds like a fun project to ponder on.
#12 | |
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter) |
#13 |
Corporate Slave
@ricky how much each ng iridium, and do you still have it serviced at toyota wala bang problema pagka casa pa rin ang service then naka iridium spark plugs ka
#14 |
#15 | |
![]() @charlieXX, I think 40-50 SR. each ang price.. am I right tol ricky?
#16 |
#17 |
#18 | |
Oo tol, mejo may katok minsan sa starting eh, tapos mag-2 years na rin mga plugs ko kaya pinalitan ko na, si gian na tumira. Try ko picturan yung old spark plugs, mejo malayo na nga ang gap dun sa lead ba yun? ngaun parang bago ulit yung response ng engine. kung mapapansin niyo nung bagong kuha niyo ang yaris niyo, pagpasok ng primera tapos clutch papuntang segunda eh parang nahuhuli yung clutch natin? ewan ko mahirap explain, pero parang ganun yung feeling ulit nung napalitan na ng bagong SP. nilinisan na rin namin ni gian yung throttle kasi bumaba ng 400RPM ang idle, ngayon back to normal na ulit.. |
| RPM at 60 mph 5 speed manual | mark schofield | DIY / Maintenance / Service | 13 | 10-08-2011 12:14 AM |
| Vitz 2001 1.0 manual rpm | diesel2901 | DIY / Maintenance / Service | 4 | 09-23-2011 12:02 AM |
| The "let's brainstorm how to make a piggyback work" thread | eTiMaGo | Forced Induction Forum | 83 | 08-17-2011 03:54 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
| Source code for Yaris Tachometer | metalshark | DIY / Maintenance / Service | 27 | 04-06-2009 12:41 AM |
