Old 10-31-2011, 01:54 AM   #1
silver_echo
ekodrvr
silver_echo's Avatar
opposed piston, opposed cylinder?
hey CTScott, take a look at this.
anybody else heard about this? looks like it will make a great engine design.
http://www.ecomotors.com/
i like this smiley...
silver_echo is offline   Reply With Quote
Old 10-31-2011, 02:50 AM   #2
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
I'm sure it's a a lot more efficient with modern fuel injection and computers to control timing but its not a new design. The opposed piston engine has been around since the early 1900's
Stove is offline   Reply With Quote
Old 10-31-2011, 03:15 AM   #3
silver_echo
ekodrvr
yes, the opposed piston has been around, and the opposed cylinder is in my current car(subaru), but have there been cars with both?
Old 10-31-2011, 05:55 AM   #4
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
if you look a the design this is not your standard boxer engine. its 2 pistons pushing on each other. There is no "head", kinda weird setup. Looks PAINFUL to work on. I'm curious to see this in action
-Derrick-
Old 10-31-2011, 03:17 PM   #5
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Am I the only one that sees an intake but no header? Or is just that the header is off to the side so it disappears in the cut-away?
Old 10-31-2011, 04:12 PM   #6
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
I almost feel bad for people like this. Their have been so many of these types of engines that have simply vanished, either because they were horrific or someone bought the patents to kill it.
Colin Chapman disciple
Old 10-31-2011, 08:57 PM   #7
yaris2010RS
yaris2010RS's Avatar
i like it
Old 10-31-2011, 10:37 PM   #8
Stove
Stove's Avatar
There was aircraft with opposed piston used in WWII, that's where I knew of it from. I don't know of any cars that have utilized it.
The opposed cylinder (boxer) has been in common use in automotive and aircraft since at least the 1930's.
Old 10-31-2011, 10:40 PM   #9
thepartsmancometh
Drives: '08 LB, '07 WRX
prepare for your mind to be blown.
If you want crazy, look up the napier deltic. They used them in diesel locomotives in the UK.
animation
thepartsmancometh is offline   Reply With Quote
Old 10-31-2011, 10:54 PM   #10
Stove
Stove's Avatar
animation
Whenever I see stuff like that, all I can think of is how much work it must be to troubleshoot issues.
I think the craziest one I know is the Gnome Radial Aircraft Engine. The crank was the mounting point to the air frame and the engine case spun with the prop mounted to it
Gnome Engine
engine starts at about 1:30 in to it
Old 10-31-2011, 11:56 PM   #11
mr_miles
Drives: 2013 Yaris
usually all you have to do to stump someone these days is say RX7. lol. Magical spinning triangles, etc.
Old 11-01-2011, 12:27 AM   #12
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Good ol' rotaries... when you look at it, they were quite efficient. The Wankel, on the other hand, was a real bag of snakes, but one must admire Mazda for pursuing the design.
Many German aircraft ran a Junkers Jumo double-opposed diesel for power... Let's complicate things here: two cranks, 12 pistons, no cylinder head. They were used in flying boats, and one really doesn't want an unreliable engine in that application!
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 02:05 AM
NEED ENGINE CHECK LIGHT CODE LIST Attitude Forced Induction Forum 12 04-11-2011 07:38 PM
DIY Hood Cylinder churp Cosmetic Modifications (Exterior/Interior) 46 06-25-2007 06:46 AM
Canada Only - Maybe a $1000 enviro rebate on Yaris> MDF New YARIS Purchase Forum 45 05-01-2007 09:17 PM
