Old 10-31-2011, 01:13 AM   #1
rickyml
rickyml's Avatar
Drives: Yaris 2008
Car Battery Replacement
Ano po ang magandang brand to replace our battery?
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 10-31-2011, 01:41 AM   #2
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
AC Delco 240sar lang with 1 year warranty
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 10-31-2011, 02:43 AM   #3
syntax
syntax's Avatar
@ insan malapit na ba palitan ang battery ni bluerider?
Old 10-31-2011, 03:21 AM   #4
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Thumbs up
I suggest you go for Yuasa or Panasonic (Japan made preferrably). They are bit pricey but you will get what you have paid for.
The local AC Delco nowadays are not same quality 3 years ago and they are now made in saudi/india.
Also go for a higher ampere hour rating as long it fits on the battery mount
my 5 halala opinion.
ricepower is offline   Reply With Quote
Old 10-31-2011, 05:32 AM   #5
syntax
syntax's Avatar
+1 i think mas mataas ang amps ngayon ung nakalagay kay shadow.
Old 10-31-2011, 05:50 AM   #6
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
+1.. medyo napansin ko nga yan,, unlike before matagal bago sumuko ang ac delco pero ngaun almost 1 year a half or wala pa... nxt time yuasa din ang balak ko with a bit higher ampere...
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 10-31-2011, 06:43 AM   #7
rickyml
rickyml's Avatar
Drives: Yaris 2008
oo insan, mag 1yr & 1/2 na kc yung battery non simula nung pinalitan.
Old 10-31-2011, 06:45 AM   #8
rickyml
rickyml's Avatar
Drives: Yaris 2008
ok go ako sa yuasa w/ a bit higher ampere. tnx guys!
Old 10-31-2011, 06:59 AM   #9
syntax
syntax's Avatar
Old 10-31-2011, 07:21 AM   #10
rickyml
rickyml's Avatar
Drives: Yaris 2008
mga approx. magkano ito?
Old 10-31-2011, 09:52 AM   #11
syntax
syntax's Avatar
nung grandmeet nagpalit ako mismo dyan sa alkhobar, nasa 200SR sya, cguro hindi rin lalayo ang price, parang humigit kumulang hehehehehe
Old 10-31-2011, 05:08 PM   #12
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
sa mga tropang khobar dyan especially ricepower, paki tulungan ako sa pagbili ng battery (wala akong alam dun eh, hehehe), this coming salary bibili na ako, malapit ng bumigay, naghihingalo na everytime I start the engine...hehehe
Ciao !!!
xtremist is offline   Reply With Quote
Old 10-31-2011, 11:49 PM   #13
ricepower
ricepower's Avatar
No problem. Anytime..If I were you, simulan mo nang bumili ng Jump Start cable kasi mas madaling humanap ng car na kakabitan ng battery kaysa sa car na may jumper cable.
Old 11-01-2011, 12:36 AM   #14
rickyml
rickyml's Avatar
Drives: Yaris 2008
agree ako dito...
@jeff sabihan mo ako kung magkano yung yuasa?
Old 11-01-2011, 12:50 AM   #15
syntax
syntax's Avatar
yan si ricepowah, anytime handang tumulong sa kayaris... at nagjjoke pa hehehehehe
Old 11-01-2011, 04:11 AM   #16
ricepower
ricepower's Avatar
@Pao, naka yuasa battery yata si Big Boy Mike - BMW. Paki check na lang yung spec/model at price.
Parehas kasi kaming matic.Puwede ring walang jumper cable..ask the other car drivers or call a yarisworld member
Old 11-01-2011, 04:13 AM   #17
syntax
syntax's Avatar
hohonga pala ricepowah naka yuasa sya, nakuha nya ng 180SR ata un,
Old 11-02-2011, 04:55 PM   #18
xtremist
xtremist's Avatar
180 lang? kapag may time byahe ako thouqbah to canvass...pinahiram ako ni Frankie Boy ng Jumper cable, makapal kc ung sa kanya, tumingin ako nung nakaraan kaya lang puro manipis nakikita ko, try ko ulit maghanap.
Ciao !!!
Jerkratt - Photo Scavenger Hunt Jerkratt Photo-Video-Media Gallery 3 03-04-2009 09:03 AM
