Old 10-31-2011, 08:08 AM   #1
jiamanuel
green arrow
Drives: Yaris 2008
Drive Belt
Mga tol ilang kilometer bago palitan ang drive belt? Sino sino na sa Yaris member nagpalit at ilang kilometer?
jiamanuel is offline   Reply With Quote
Old 10-31-2011, 09:43 AM   #2
syntax
syntax's Avatar
hmmn.. not sure pre, i think but not sure si kenn nagpalit na ata, pero hindi na sya active sa forums eh, try ko ask si mike bigboy, sya ata ung nagpalit ng drivebelt ni kenn....
pero sa opinion ko lang ( correct me if i'm wrong mga kayaris) kapag may nakita ka na crack or worn part ng belt or maingay na kailangan na palitan...
Old 10-31-2011, 12:13 PM   #3
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
like ung belt ni storm, pag start umiingit, pero matigas ulo di pa rin nagpapalit, hahaha F.Y.I. 84k na takbo ni storm
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 10-31-2011, 01:43 PM   #4
EjDaPogi
EjDaPogi's Avatar
Drives: 2008 Yaris Fleet (SilverWings)
at 60KM dapat palit na ng drivebelt
EjDaPogi is offline   Reply With Quote
Old 11-05-2011, 05:14 AM   #5
Yaross
Yaross's Avatar
Drives: 2006 Yaris HB 5DR
actually, inspection at 60T, adjust kung pwede pa, replace kapag hindi na. kung di ka sigurado, palitan mo na gaya ng sabi ni el presidente EJ.
part number: 90916-02556
yung OEM ay nasa SR100+ yata, yung third party brands ay nasa SR35.
Yaross is offline   Reply With Quote
Old 11-05-2011, 06:46 AM   #6
marble_bearing
marble_bearing's Avatar
Drives: 2008 yaris y silver
marble_bearing is offline   Reply With Quote
Old 11-05-2011, 10:15 AM   #7
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
Noted mga bro 60K
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 11-08-2011, 03:40 PM   #8
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Originally Posted by charlieXX View Post
Noted mga bro 60K
better to have an extra/spare serpentine belt in your toolkit. Ensure that you have the right tool(spanner) to fix it
ricepower is offline   Reply With Quote
Old 11-08-2011, 05:23 PM   #9
rickyml
rickyml's Avatar
Drives: Yaris 2008
anong spare part number nito?
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 11-08-2011, 11:33 PM   #10
EjDaPogi
EjDaPogi's Avatar
127sr po ang price sa Toyota Dhahran
Old 11-09-2011, 03:13 AM   #11
Yaross
Yaross's Avatar
yan po dahilan kaya third-party belt ang gamit ko. pwedeng makabili ng 3-4 na belts sa katumbas na halaga ng OEM belt.
bumili ako ng isa, tapos tinabi ko yung lumang belt sa lagayan ng spare tire in case of emergency.
kung hindi ako nagkakamali, magdadalawang taon na ang belt ko.
Old 11-09-2011, 05:02 AM   #12
rickyml
rickyml's Avatar
Drives: Yaris 2008
naalala ko nung 40k na ako pinalitan na ng toyota yon. pero gusto ko bumili ng spare.
Old 11-10-2011, 09:30 AM   #13
jiamanuel
green arrow
Drives: Yaris 2008
sabi sakin sa red cap umaabot upto 100k ang belt pero depende talaga sa gumagamit daw. 50K nako pero ok pa!!!
seat belt chime disable? Lewis DIY / Maintenance / Service 19 05-25-2012 04:36 PM
serpentine belt for 2007 yaris hatchback nikki9 DIY / Maintenance / Service 4 04-09-2011 09:22 AM
squeaky belt TickleTimeTim DIY / Maintenance / Service 14 03-16-2011 11:49 PM
HELP!? HORRIBLE drive home during first REAL Snow in Michigan, paulyd0021 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 12-11-2009 08:07 PM
HELP!? HORRIBLE drive home during first REAL Snow in Michigan paulyd0021 General Yaris / Vitz Discussion 32 12-10-2009 01:23 PM
