Old 11-01-2011, 05:56 PM   #1
DuckHunt
Drives: 2007 & 2008 Yaris Sedans
Rear Defroster Issue
I have a 2008 Yaris sedan. I noticed this week that the rear defroster is not working. The light comes on when you push it in and I can hear a relay click under the dash as if everything is working but it isn't heating. The fuse under the dash is good. Though there isn't one under the hood labeled for it, I confirmed there are none blown there either.
Based on a recommendation on another post, I check the voltage across the terminals on the back glass. I get nothing. I wanted to try to take off the trim panel, but I figured I would ask if there is a trick to it before I break something.
Any suggestions? Comments?
DuckHunt is offline   Reply With Quote
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
