Old 11-07-2011, 12:36 PM   #1
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
Paint Spray Accidental / Done On Purpose
Let me explain, it is not a full paint spray of color but more of a color white sprayed on my Yaris and it is all over, how could I remove it effectively and easy at least.
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 11-07-2011, 12:57 PM   #2
A-Dingo-Ate-My-Baby
Drives: yaris
if it was waxed, the paint is likely on the wax only and fairly easy to take off
1) take a q-tip dipped in denatured alcohol and
2) try to rub a single paint drop off
did it work ?
a) if so, you will need a professional detail shop ( or tools) to take off the rest of it with power buffing agents
b) if NOT, the paint is there to stay and you need a lot more work
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 11-07-2011, 01:18 PM   #3
charlieXX
Corporate Slave
charlieXX's Avatar
Did not try the alcohol yet, will do that.
tried Mothers Cleaner wax today though and the roughness and paint speckles is still there specially on the rubber parts and glass.
Old 11-07-2011, 02:48 PM   #4
weedtank
I need more stars
weedtank's Avatar
Drives: Liftback
claybar will usually do the trick. Make sure to wax the area afterwards
weedtank is offline   Reply With Quote
Old 11-07-2011, 04:07 PM   #5
charlieXX
Corporate Slave
charlieXX's Avatar
Claybar??? ohhh I'm not too patient on this type.
Any idea on professional services how will they do it? with buffing wheels?
Old 11-08-2011, 02:19 AM   #6
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Definitey try the clay bar first.
Check out my Build thread:
Old 11-08-2011, 04:23 PM   #7
nemelek
DWEED
nemelek's Avatar
Good luck. I dropped a spray can and the head broke off and sprayed the tail gate of my truck. Even though the truck was well waxed, nothing seemed to work in getting the speckles off. Had to scrape each one off with my thumbnail.
Old 11-09-2011, 01:13 PM   #8
charlieXX
Corporate Slave
charlieXX's Avatar
Oh my situation is worst, it is like there was a plant painting on-going nearby and the wind blew in the speckles and it is all over, specially when you run your hand through the glass and roof it is all over.
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
color match spray paint - experiences? dmfang Cosmetic Modifications (Exterior/Interior) 2 07-28-2011 12:10 PM
spray paint removal of cars paint job big lo Wash, Wax, Detailing, Exterior Repairs 15 06-19-2010 04:15 PM
Matching spray paint to Polar White jdubau55 Cosmetic Modifications (Exterior/Interior) 1 03-13-2007 06:01 PM
