Old 11-08-2011, 12:02 PM   #1
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Need Clutch
Need to upgrade my clutch. Making about 210hp right now. Looking for ideas on what brands are good.
Old 11-08-2011, 12:04 PM   #2
Clutchmasters is the only way to go. Even at Stage 4, it's nearly close to OEM pedal feel.
Exedy Stage 1 was way too stiff.
I would go CM Stage 3, you won't regret it.
Old 11-08-2011, 03:07 PM   #3
Yoda
Yoda's Avatar
Maybe but it's kinda pricey. Almost double the cost exedy
Old 11-08-2011, 03:08 PM   #4
act
or support local vendor
Old 11-08-2011, 03:44 PM   #5
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I second the Clutch masters...you get what you pay for.
I'm running a stage III with the 9lb flywheel Garm sells...you won't be disappointed.
-Type 07 FFL-
My odometer 03/11
Old 11-08-2011, 03:56 PM   #6
Maybe, but if the Exedy sucks, what's the point?
Old 11-08-2011, 04:49 PM   #7
Yoda
Yoda's Avatar
You know exedy doesnt suck. I am all for supporting the vendors as I do all the time. But when money is getting tight you have to look out for your needs first. In this case it's out of my price range.
Old 11-08-2011, 04:57 PM   #8
just to be clear, here was the original request:
I'll be more specific: I drove in stop and go traffic with an Exedy in my car, and it sucked for that. Probably great for racing, but not easy for street driving. I'm happy to sell you one.
I'm glad you like to support vendors -- what brand would you like a quote on?
Exedy
CCI
ACT
other?
Old 11-08-2011, 04:57 PM   #9
mazilla
advocatus diaboli
mazilla's Avatar
Then why are you asking about it? Seems to me you have your heart set on Exedy...
-Type 07 FFL-
My odometer 03/11
Old 11-08-2011, 06:10 PM   #10
Clutchmasters:
$369 shipped Stage 1
$479 shipped Stage 2/3/4
$409 shipped aluminum flywheel
ACT are $489-$499 for all stages
CCI:
$379 shipped Stage 1/2/4/5
$489 shipped Stage 3 (segmented kevlar)
$289 CCI Steel flywheel 9.5lbs
$299 CCI steel flywheel 8.4 lbs
Exedy
$159 Stage 0 (OEM)
$299 Stage 1 (organic)
$379 Stage 2 (cerametalic)
Spec
$299 Stage 1
$389 Stage 2
$399 Stage 2+
$359 Stage 3
$499 Stage 3+
$359 Stage 4
$499 Stage 5
$389 Spec Aluminum flywheel
Jun (+ some shipping!)
$699 Stage 1
$640 Aluminum flywheel
TRD Japan - (+ some shipping!)
$550 Stage 1
$599 Flywheel
Old 11-08-2011, 06:43 PM   #11
03Z33
03Z33's Avatar
Drives: TCR10
Considering your power level and budget I think Clutch Masters Stage 1 will work best for you.
Stage 3 is $110 more but keep in mind it also lasts 2-3 times longer on average which will save you money in the long term on clutches, flywheels, downtime and labor.
03Z33 is offline   Reply With Quote
Old 11-08-2011, 07:42 PM   #12
mazilla
advocatus diaboli
mazilla's Avatar
Bingo...which is why I went with it, to save time/money in the long run. Not to mention the clutch feels spectacular, I drive in bumper to bumper LA traffic almost every week. My average work commute is 250 miles.
-Type 07 FFL-
My odometer 03/11
Old 11-09-2011, 09:28 AM   #13
Yoda
Yoda's Avatar
Clutchmasters:
CCI:
Exedy
$159 Stage 0 (OEM)
Spec
$299 Stage 1
$389 Stage 2
$399 Stage 2+
$359 Stage 3
$499 Stage 3+
$359 Stage 4
$499 Stage 5
$699 Stage 1
$550 Stage 1
$599 Flywheel
If you can get me the tq ratings on the CM stage 1 and Spec stage 1. You got yourself a sale.
Old 11-09-2011, 10:30 AM   #14
I'll do that today for you, and thanks, I always appreciate the chance to earn your business.
Old 11-09-2011, 01:27 PM   #15
We called both companies.
CM Stage 1 70% increase holding capacity
Stock is 120-140 TQ and CM Stage 1 is 180 TQ
Spec Stage 1 15% increase holding capacity
Stock is 120-140 TQ and Spec Stage 1 is 150-160 TQ
Both manufacturers recommended you go for a Stage 3/4. Remember, we don't know the exact torque you're making when discussing this.
So this is our "official" disclaimer, that we recommend more than a Stage 1. (have to say it)
Clutchmasters supply OEM toyota throwout bearing vs. Spec sometimes use aftermarket
Clutchmasters use steel backed plate vs. Spec use steel "lined" plate
Clutchmasters use standard sprung clutch vs. Spec use "double" sprung clutch which can sometimes cause stiffer pedal feel.
Old 11-12-2011, 10:19 AM   #16
Yoda
Yoda's Avatar
Ok you did your job a sales person and a good vendor. I work in sales n can appreciate the effort you making. I will go with the CM then. Let me move some money around n I will get back at you. Wish I had more employees that had your business sense lol.
Old 11-12-2011, 10:59 AM   #17
Old 11-12-2011, 01:13 PM   #18
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
So for those of us that have not gone FI, is the CM overkill? I'm looking to upgrade my clutch and flywheel when I drop in my frankenstien transmission, but likely won't be going FI for some time.
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 07:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Restarting car after popping the clutch... PaidTimeOff General Yaris / Vitz Discussion 21 02-26-2009 01:40 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
