Old 11-09-2011, 01:52 PM   #1
Gogogordy
Drives: Miss my Yaris, love my Jeep jk
Very fast idle, on cold start-up
My 2011 seems to have an abnormally fast idle just after starting from cold.
So fast, that I'm hesitant to put it into a gear until 20 or 30 seconds afterwards, when it settles down.
Seems kind of odd, fuel-injected and all. I don't recall another FI car being like that.
It's a 2011 LB, automatic....anyone else?
Gogogordy is offline   Reply With Quote
Old 11-09-2011, 02:10 PM   #2
Would help if you'd tell us what you consider very fast idle. Cold, I rev 1300-1500 rpm. I think we all do.
Old 11-09-2011, 03:30 PM   #3
Gogogordy
Tachometer? Whats that?
Very fast idle, being substantially faster than its normal idle when warmed up...and enough to cause a fair clunk when putting into gear if I don't wait for it to slow down (which it does eventually)
Old 11-09-2011, 08:31 PM   #4
mine will idle that high when its cold....most cars do
but i guess you're used to 70* weather all the time and it never happens?
Old 11-09-2011, 09:52 PM   #5
NZ-FE Vios
Only Timing Chains
Drives: 09YarisSedan, 94Truck22re
It's just warming up, I usually like to let mine sit a few minutes before taking off . Totally normal. It should settle quickly.
NZ-FE Vios is offline   Reply With Quote
Old 11-09-2011, 10:20 PM   #6
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
It's normal. Just the engines way of getting the emissions up to operating temperature and if I were not driving a manual I'd probably notice it more when I put it in gear. I do have and '08 RAV4 as well and it does exactly what you describe and is a 2.4 liter
Old 11-10-2011, 12:14 AM   #7
Gogogordy
Thanks...
Sounds like its not out of the normal, (our Scion xD is my point of comparison) so Ill stop Worrying about it.
Thebarber....it isn't always 70 degrees here. Sometimes it dips down to 67 or 68
Thanks for the help folks!
Old 11-10-2011, 06:01 AM   #8
Originally Posted by Gogogordy View Post
Thebarber....it isn't always 70 degrees here. Sometimes it dips down to 67 or 68:
brrr
lol
Old 11-10-2011, 06:12 AM   #9
BLH
Drives: 2007 Yaris Sedan
My 2007 is the same way.
You may also notice the automatic transmission shifts at a different RPM than when warmed up. Mine will not go into fourth until the Cold LED symbol goes off.
Reluctant upshift to 3rd while cold (auto trans) pauljk General Yaris / Vitz Discussion 40 01-22-2011 06:04 AM
Yaris does not start jake002 DIY / Maintenance / Service 21 01-05-2010 08:53 AM
longer turn over on start w/ cold weather manborn General Yaris / Vitz Discussion 20 02-04-2007 11:35 PM
