#1 |
![]() Drives: 2008 Yaris white Join Date: Dec 2009
Battery
Hi fellow Yaris.
My battery on my 08 3dr hcth is dying on me. I had have a jump this afternoon to get back home. The battery has been in the car since 08. This is the first thing I've had to replace "Yarrie" since I bought "her". I stop by AutZone and the guy said the tester indicated that the battery was "bad". Yes it was bad it almost left me strand in the middle of town. A woman next to me gave me a jump, I had jumper cables.
Probably should have gotten a little more life out of it but. Was it the original? You sit in the car with the engine off running the radio or CD player for long periods of time? Dunno but typical life expectancy is 3-4 years though some have reported longer.
#3 |
![]() ![]() ![]() ![]() ![]() Drives: '09 Yaris carmine red 2d HB Join Date: Jun 2009
Time to get a new battery.
When a battery goes bad depends on many varibles but, 3 years is not that uncommon. Contrary to popular belief, heat (not cold) is the biggest killer of batteries and I see you live in Florida. The Autozone "duralast" battery is acutually very good. |
#4 |
![]() ![]() ![]() Drives: 2008 Yaris Liftback Black Join Date: Oct 2008
This happened to me. Battery died in 2010, was a bad battery after getting it checked by autozone. Unfortunately, mine died in the winter (it was really really really cold that day). I believe it was due to the stock battery's low cracking amps. Replaced it with a duralast gold with higher rated cold cranking amps and it's working great so far. Had to remove the plate thing at the bottom where the old battery sits because the duralast gold sits too high with it in place.
2008 YARIS/VITZ LIFTBACK - BLACK SAND PEARL Representing The Midwest! http://www.cardomain.com/ride/3132598 |
#5 |
![]() ![]() ![]() ![]() ![]() Drives: 2008 HB, A/T, Power W/L/M Join Date: Oct 2008
Just put a new Excide 35 series in my '08 hatch too. Don't remove that tray. Just bend the tab at the back of the hold down and you're golden! Worked great for me...
Never take eyes off opponent - Bruce Lee |
#6 |
Yes, just make sure you get a #35 battery no matter what brand you get.
The #35 is an industry designation and any #35 battery will filt. |
#7 |
![]() Drives: 2007 Yaris HB Bayou Blue Join Date: Jul 2007
Just replaced the battery on my 07 hatchback with a Toyota battery I bought on sale from Elmore Toyota. I was tempted to leave the tray out since the new battery was a bit too tall. I got it to fit by doing exactly what you did. After I bent the tab on the back of the hold down, it fit nicely.
#8 |
![]() ![]() ![]() Drives: 2010 Prius, 2007 Yaris Sedan Join Date: Oct 2009
I have had no issues with my stock battery so far on my '07 sedan, but I don't imagine it will last a whole lot longer. I'm going in the other direction then all of you though, and will be getting a smaller Deka 15 lb battery...
#9 |
Nothing beats a Toyota!
Drives: 2013 Yaris 5 dr liftback Join Date: Jan 2009
I had to replace mine after a year, but it was because the ecometer was sucking the life out of it.
I bought a new one at WallyMart and it had more cranking amps than the OEM battery. You can't go wrong if you get Wallymart's top of the line battery!
Big Dave Indianapolis, IN Synthetic Oil....its in my car.....for at least 10,000 miles! ![]()
#10 |
Drives: 2007 Yaris Sedan Join Date: Nov 2011
My stock battery from my '07 died on Sunday - replaced it with the less expensive battery from autozone - the battery appears shorter than the original causing a problem with the rods that secure the battery with the engine hood holder ... any suggestions ?
#11 |
You could go to HD or Lowes and get some threaded rod of the appropriate diameter, cut to fit, get a couple of the right size washers and nuts and make your own. What I'd do in a pinch. Don't use that piece anymore, have it in a box somewhere.
#12 |
they also sell shorter j-hooks at pep boys, and i'm sure advance and autozone.
#13 |
Dont sell your battery short. The one in my ECHO was seven years old when I sold it.
#14 |
![]() ![]() ![]() ![]() ![]() Drives: it is kinda stock Join Date: Oct 2010
#15 |
![]() ![]() ![]() ![]() ![]() Drives: '08 LB MT Bayou Join Date: Oct 2008
Stick something under the battery to raise it up a bit. I put a redtop in mine and it came with a plastic spacer to raise the height.
#16 |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2010
I am on my 3rd battery in my 07. Last battery I bought was from Discount Auto Parts. I bought the best one had a 3 year free replacement and just had it replaced after 27 months. It was cranking very slow. I took it to Advance Auto and they bring out the 1,700 dollar tester abd tell me it's "Good" I went to another place got same answer. I had to park where I could push start it if needed every time. after 4 days of cranking slow it finally took a dump. And Discount tested it said it had good charge but low cranking amps
and replaced it free.
#17 | |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
I now have a similar problem with my newly acquired Mazda and i suspect the alarm system is draining the battery prematurely..
Have Yaris will travel.. |
#18 |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Sep 2010
I still have the original battery in my 05' echo, and my dads 05' echo. Seems like living in florida gives you premature battery failure lol Thats with -40*C in the winters too
I do have a redtop at work waiting to go in my car though
05' Echo Hatch - Greddy Supercharger - rear disc |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 02:15 AM |
| DIY: Braille Battery install | texkid | DIY / Maintenance / Service | 39 | 02-19-2013 03:40 PM |
| Toyota Yaris Battery Light On - Repair | gabo | General Yaris / Vitz Discussion | 1 | 08-24-2011 08:21 AM |
| Charging voltage for stock battery | Vinceb | DIY / Maintenance / Service | 3 | 02-12-2011 01:10 AM |
| Installation of a Battery Isolator | frostbitten | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 10-07-2009 01:11 PM |
