Old 11-17-2011, 07:09 AM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Solid Bushings... Custom only?
I am thinking of a solid bushings on wishbone / anti-roll bar etc... since I am having wheel hopping when trying to do a burnout.
Is there any aftermarket parts for the first generation yaris?
What are your thoughts?
Old 11-17-2011, 10:23 AM   #2
1. What motor mounts/trans mount are you using now?
2. Are you using a torque damper?
3. What is your suspension and how do you set it up for drag racing?
Old 11-17-2011, 05:19 PM   #3
Parmas
Parmas's Avatar
1. The rear engine mount is solid nylon while the others are stock
2. Yes Nittto if yours
3. D2 Racing shocks and springs / front and rear, don't know the exact compression of the springs since they were bought 2nd hand
Old 11-17-2011, 05:43 PM   #4
Are your struts/shocks adjustable? What settings have you tried?
I would open up that damper, take out the rubber rings, and fill that with urethane like some people do on the trans mount. That will help a lot. (but it won't be adjustable)
Old 11-17-2011, 06:02 PM   #5
Parmas
Parmas's Avatar
Yes they are adjustable. I have the rear shocks slightly higher than front. Camber is near 0 each.
I will check on the damper thanks for the heads up...
What about the wishbone bushings? I am thinking of removing rubber bushes and make them solid screw type fitting instead plus bracing
Old 11-17-2011, 08:30 PM   #6
Viperoni
Drives: 2005 Toyota Echo
Stiffen up the sturts/coilovers rebound/compression
Having one solid mount, especially one that strong, while having the others stock isn't a good place to be. Stiffen up the others by at least filling them with urethane.
Solid Delrin or Nylon ones would be custom I'm sure.
If you want to go completely solid (steel), you MUST replace all at the same time. Think about what will happen if you don't.
Also, I found that sometimes I do get wheel hop and sometimes I don't. I haven't figure out exactly how to get around it though, but I'm leaning towards that the clutch needs to get popped from a high RPM - don't know if this is actually true though.
2006 Saturn Ion Redline
Old 11-18-2011, 03:05 AM   #7
Parmas
Parmas's Avatar
What do you think about super pro ?
They have available all front bushing made of polyurethane for our yaris ----
GO TO ->>> http://203.31.191.243/fulcrumCat/
SEARCH VEICHLE --> ECHO/YARIS
APPLIES TO ->>> FRONT ONLY
CLICK SEARCH
Old 11-21-2011, 01:03 PM   #8
Parmas
Parmas's Avatar
What do you think about this company products? http://www.superpro.eu.com/whysuperpro/
Old 11-21-2011, 02:03 PM   #9
You are using slicks right? What's your pressure? I get no wheel hop at all, and I am not using solid mounts.
I set my suspension soft in front, full hard in the rear. Lift in front is ok on launch, the stiff rear causes the front to come back down and bite.
Old 11-21-2011, 03:16 PM   #10
Parmas
Parmas's Avatar
No I am still on semi-slicks. Tried 15psi - 20 psi pressure but still especially on wet road.
I have my shocks hard set on both rear and front.
Old 11-21-2011, 08:06 PM   #11
Viperoni
I've heard of superpro, don't know how good they are.
Whiteline makes caster bushings for the Echo, I gotta scheme some way of getting them in for next year (if I don't make my own LCA's).
Double adjustable struts/dampers would be the key, but lowering your front spring rate should also help a bit. For all out drag racing, the front spring rate should be (relatively) low anyhow.
Old 11-22-2011, 12:11 AM   #12
I would try filling your other two front mount first before changing all those bushings.
My motor thrashes HARD if the wheels spin at all, but I know the stock mounts are stupid soft.
Old 11-22-2011, 01:42 PM   #13
Jason@SportsCar
This could be your problem...
If we get wheel hop under acceleration we look for one of two things. If the wheel hop is bad, like it feels as if the tires are bouncing off the ground, that usually indicates a blown shock - it cant control the spring so it hops the tires. If it is more like chatter, the tire is trying to hook but just cant bite, that usually means to much compression damping.
The downside to coil-overs that change rebound and compression simultaneously is that by the time you have adequate rebound control, you typically have excessive compression damping. If you know the shocks are still good, try softening the front damping.
Old 11-22-2011, 01:47 PM   #14
What's a semi-slick? Drag radial?
Old 11-22-2011, 02:23 PM   #15
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
probably like 100 treadwear tires, like R888.. not slicks per se, but such low treadwear that have tread, its not save to drive on the wet roads
-Derrick-
Old 11-22-2011, 03:15 PM   #16
^ ha, those are my street tires
Old 11-23-2011, 12:43 AM   #17
Viperoni
Agreed, that was going to be my next suggestion - lower the front dampers compression setting if possible.
A tire with a soft sidewall should help too - R888's don't count lol
Old 11-23-2011, 09:18 PM   #18
TURBO YARIS
Your tire pressure is too low. Radial tires sidewalls are hard not soft like slicks. The wheel hop is due to the sidewall not supporting the tire enough.
TURBO YARIS is offline   Reply With Quote
Converting from Custom Wheels back to stock!!! daddz07 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 09-23-2010 08:45 PM
Bronzoil Cable Bushings for the Yaris/Echo now available! TWM Performance TWM Performance 58 03-31-2010 10:19 AM
Custom tags and custom vinyl ellenbetty Cosmetic Modifications (Exterior/Interior) 9 09-11-2009 03:13 PM
Custom install - Hertz, eD, JL - lots of pics The Spectacle In Car Entertainment + Electronics (audio / video / alarm) 34 04-14-2009 12:57 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
