Old 11-17-2011, 11:02 PM   #1
mr_miles
Drives: 2013 Yaris
Clutch adjustment?
been looking the car over for a while, trying to figure out how to adjust my clutch properly for what I need. I have to floor the clutch for it to shift or i will grind gears, which is not ideal for me, I'm used to my rx7 where at about 3/4 pedal it was open enough. under the hood i don't see if it's possible, and behind the pedal I cant tell if that adjusts out anymore (or at all). where would I look to do so?
Old 11-21-2011, 12:27 AM   #2
johnny_vitz
Drives: 2005 Toyota Echo
If it's like the echo, it's not adjustable (iirc) Maybe your rx7 uses a clutch cable instead of hydraulic? You may just have to get used to it :(
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 11-21-2011, 03:51 AM   #3
mr_miles
Drives: 2013 Yaris
nah, the RX7 was hydraulic but it was perfect for me. I'll give it another look see, and if it's not adjustable i'll have to figure something out, like a rubber boot or something i can attach to the pedal give it just a little more movement.
Old 11-21-2011, 11:36 AM   #4
It's not adjustable. Lifting from the floor, when does it engage exactly?
There are aftermarket clutches that release the plate higher up on the pedal -- it's an expensive mod just for that, though.
Old 11-21-2011, 10:34 PM   #5
mr_miles
Drives: 2013 Yaris
dang, that's nothing i like to hear, I'll have to figure out the point that it starts to engage, don't know off the top of my head.
it's just an annoyance, mostly. if i wouldn't rest my left foot on the dead pedal area i wouldn't have the problem, seems i touch that area with the left of my foot sometimes and it causes me to think i have the clutch depressed completely.
Old 11-22-2011, 08:12 AM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
It could also be your footwear: I have problems in the winter with my heavy boots, but not in the summer with running shoes. Here's one possible solution.
Old 11-22-2011, 04:45 PM   #7
mr_miles
Drives: 2013 Yaris
makes it a tad easier knowing there's a write up and it's been done before, lol. I was thinking about removing that entirely and mounting a metal dead pedal too.... I have the easiest time driving in my converse, so i've been wearing them most the time. i can drive in my boots but it gets a little difficult at times :p
Old 11-25-2011, 01:09 PM   #8
mr_miles
Drives: 2013 Yaris
engages about an inch from the floor. guess I'll just deal with it :x
Old 09-13-2016, 05:54 PM   #9
spookybathtub
Drives: 2007 Yaris HB
This is annoying for me too. My shoes are size 12, and I did the "big foot mod" already, which helps. But still, it's hard to press the clutch pedal all the way down when I'm wearing shoes with rigid soles. About 10% if the time, it grinds as I try to shift with the clutch partially engaged. To avoid this problem, I usually drive barefoot.
spookybathtub is offline   Reply With Quote
Old 09-13-2016, 11:12 PM   #10
You need to adjust the pushrod connected to the pedal. Loosen the lock nut and then pull the pin out and give it a couple turns out. Just make sure you still have freeplay when the pedal is all the way up or you'll burn out the through out bearing.
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 07:14 AM
clutch adjustment 1krzys DIY / Maintenance / Service 0 09-01-2011 03:10 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
