#1 |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2010
Dodge Ram 1500 wont crank over
Trying to help my dad fix his truck. He started having problems with it "clicking" when turning to start position. He decided to replace starter and selonoid. Now it still wont start. I tried replacing starter relay and still wont crank. I was going to put another neutral safety switch but the one I got didn't match old one so I have not pulled it out yet. What else could it be?
Also his automatic shifter has not been able to go into Park for over a year and he has been starting in neutral. |
#2 | |
USAF_SrA_E-4
I found ur problem... ITS DODGE RAM lol
#3 |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
The "clicking" is probably the solenoid trying to fire, and the real problem is that it isn't getting any juice from the battery - checked the voltage?
#4 |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
The battery might need recharging. Try jump-starting it. If that doesn't work, it might be a bad battery. Ask your dad when he got it. If he says it's been about 5 or 6 years, then it's time for a new one.
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
#5 |
I know the battery is good. It was starting sometimes and clicking others I guess. Gonna try the neutral saftey switch again and check voltage
#6 |
Let us know what uit was when you DO get it fixed, would you? always interesting to see what things really are after all the "maybes".
Toyota Yaris > Dodge Ram | RedHatch08 | General Yaris / Vitz Discussion | 1 | 06-14-2010 08:07 PM |
crank, fire, hesitate, crank, fire, run, gas smell | twowheels | General Yaris / Vitz Discussion | 9 | 06-25-2009 07:11 PM |
Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
Crash: My Yaris vs. Dodge Ram | j8smith | General Yaris / Vitz Discussion | 20 | 12-13-2006 06:28 PM |
