Old 11-21-2011, 09:50 PM   #1
stevethegimp
Drives: '09 Blazing Blue 3D LB
11-20-11 Marana Autocross
So took the Yaris out for the first time since the turbo install. It was a very fun course and we had a huge turnout! I even had my first spin out ever, quite the experience! Also I have never seen so many people looking around my engine bay....pretty hilarious.
Here's the obligatory Yaris-cam-
http://www.youtube.com/watch?v=KWqGzA_yZag
4 tires? Bah 3 will do fine!
Doing my finest smooth criminal lean.
Slaloms are always fun!
stevethegimp is offline   Reply With Quote
Old 11-22-2011, 12:29 AM   #2
NZ-FE Vios
Only Timing Chains
Drives: 09YarisSedan, 94Truck22re
Looks like a good time for sure. How'd the turbo feel at low range ?
NZ-FE Vios is offline   Reply With Quote
Old 11-22-2011, 11:37 AM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
what kinda turbo? zage? or custom? I am also curious how much boost and the boost lag (if any)
-Derrick-
Old 11-22-2011, 05:17 PM   #4
stevethegimp
NZ-FE: The turbo is pretty gutless below 2000 rpm but ramps up pretty quickly after that, it pulls hard the rest of the powerband up to redline! Definitely a marked improvement.
ilikerice: I have the Zage kit installed and i'm currently running 8 psi boost and using the Camcon to tune fuel and cam timing! So far no pre detonation and a/f ratios at full boost are staying in the low 11's to mid 12's.
Old 11-22-2011, 06:32 PM   #5
Jason@SportsCar
How about a video without the house music so we can hear the engine?
Looking at the pics, time for some stiffer springs.
Old 11-22-2011, 06:41 PM   #6
stevethegimp
Haha all I picked up was windnoise....it was pretty bad. Time to invest in a GoPro!
What's funny is i'm currently running microimage springs, tokico blue shocks, and a 23mm rear swaybar. Have any suggestions on where to go from there?
Old 11-22-2011, 06:55 PM   #7
Jason@SportsCar
The MI springs seem plenty aggressive (at 4k front) for occasional competition and street use, but I would double that for more serious use - especially since you just added weight to the front of your car with the turbo kit.
Its time for coil-overs. Corner weight the car, set the rake, get the rates you want, have adjustable damping. You should be able to sell your setup in a snap.
If you are going to run street tires try around 400lbs up front, with R tires 500lbs+.
Old 11-22-2011, 08:24 PM   #8
stevethegimp
Haha I like where you're going with this. Might just have to pull the trigger.
Old 11-22-2011, 08:35 PM   #9
I have a set of Kido 5k/5k in stock. Also available are Cuscos and other brands with higher spring rates.
Old 11-22-2011, 10:08 PM   #10
Jason@SportsCar
Xmas is coming up, treat yourself.
Old 11-22-2011, 11:25 PM   #11
03Z33
03Z33's Avatar
Drives: TCR10
I believe the Kido's are 7K/5K, should be a nice balance for the turbo hatch.
03Z33 is offline   Reply With Quote
Old 11-25-2011, 10:58 PM   #12
stevethegimp
I'll certainly be looking into those!
Also...
Another update! With the long weekend I finally had some time to take the car to the local exhaust shop and get a new system installed. The car sounds mean with the upgraded piping + Magnaflow 2.25 exhaust! I got a few thumbs up on the drive home haha.
Autocross Sept. 18 cali yaris Tracking, Racing, Auto-X Forum 5 08-26-2011 02:21 AM
4/3/10 NTAXS Autocross - Texas Motor Speedway ozmdd Southwest 4 04-06-2010 02:04 PM
Autocross Novice School - Tampa Bay area Loren Southeast 9 01-31-2010 07:41 PM
Dallas-Ft Worth Area Autocross 1/17/2010 ozmdd Tracking, Racing, Auto-X Forum 8 01-22-2010 02:06 PM
Autocross @ AutoClub Speedway. Hosted by Speed Ventures. Jan 16/17 2009 ddongbap California 21 01-21-2010 04:59 PM
