Old 11-27-2011, 05:13 PM   #1
BURRITO
BURRITO's Avatar
Drives: 2010 yaris hb
ABS light on.... Do'h!
hello everyone,
i own a 2010 yris liftback and the other day this light came on. it is not affecting driving but i want the light off.
has anyone ran into this issue and has insight as to the remedy to this issue?
being that it is an abs issue, i am not too sure where the culprit may be. i have:
checked the reservoir and the brake fluid is just below full
i havent cleaned the brake sensors yet and reset the system (ie: un plug the battery)
just looking for what is a good approach to solving this problem. being that it is a 2010, i doubt i have abs problems already.
thanks.
BURRITO is offline   Reply With Quote
Old 11-27-2011, 05:43 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
That happened to me once.. and then I recall the light just went off by itself. fterwards I went and smeared some silicone grease over the sensor connections
Old 11-27-2011, 06:01 PM   #3
Woodsman
Drives: 2010 Yaris Hatchback CE
I've also have a 2010 hatchback but have yet to have this problem on it.
That being said I've had the same problem on other vehicles where a good cleaning at the car wash then restarting the car solved the problem. Mud splashed up on to the sensor can cause the light to come on. Spray real well inside the wheel from both sides with the pressure washer.
Even if this doesn't solve your problem it was a low cost attempt to rule out possibilities.
Woodsman is offline   Reply With Quote
Old 11-27-2011, 08:02 PM   #4
swede
Drives: 07 SDN
check out this thread, it might help
http://www.yarisworld.com/forums/showthread.php?t=11533
swede is offline   Reply With Quote
HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! mizhgolightly DIY / Maintenance / Service 45 05-03-2022 02:59 PM
abs light + hand brake light on stu 1 UK 4 09-28-2012 05:07 PM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
ABS LIGHT & E BRAKE LIGHT rossman DIY / Maintenance / Service 5 02-25-2010 11:09 PM
