Old 11-28-2011, 09:24 PM   #1
TRDMarty
FEELING STIFF without VIAGRA
Thought I'd share some pics of the new Ultra Underbracing I installed over the T-Giving Holiday.
Thanks to Jeff @ MicroImage
I installed the Front, Rear, 2 Sides & the Middle.
The last pic of my finger pointing to the bolt is to indicate that the provided bolt will not work (not long enough). Had to fabricate 2 new brackets which needed to be welded on the bolts for each rear mount point. Yes, the provided bolts are actually welded with an additional strap under the head of each bolt.
I did this at my buddies Pantera Shop
I did Panteras for 24 years, now, Yaris. I must be sick!!
Freeway on-ramps are really fun.
Old 11-29-2011, 01:47 AM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Nice shot of the whole setup!
Just wondering... Why does the undercarriage look so damn clean?!!
Old 11-29-2011, 02:40 AM   #3
YarisSedan
Drives: 08 Yaris Sedan
Wow I always wanted to do all the same underbracing but never pulled the trigger.
BTW looks like you have some cupping in the rear tires. Usually thats due to worn shocks or lack of tire rotation.
Old 11-29-2011, 03:45 AM   #4
mr_miles
Drives: 2013 Yaris
oh that's just sexy. how's she drive with all that?
Old 11-29-2011, 07:57 AM   #5
Klink10
Klink10's Avatar
Thanks for the underbody pics. Seems plenty strong now. Curious as to how much weight was added?
Old 11-29-2011, 08:04 AM   #6
TRDMarty
When I rotate the tires, I periodicly rinse down the undercarrige.
Old 11-29-2011, 08:11 AM   #7
TRDMarty
C'mon, PULL THE TRIGGER!!!
Also, no cupping on the tires. Just looks weird in the photo.
Has new shocks and every 6,000 miles the tires are rotated & air pressure is regularly checked at least once a month.
C'mon, pull that trigger!!
Old 11-29-2011, 08:16 AM   #8
TRDMarty
Don't know the exact weight of all the items combined.
My guess would be = not more than 10 Lbs
All the bracing is hollow.
Dash destroyed in electrical fire. purpleminx General Yaris / Vitz Discussion 79 06-12-2009 03:53 PM
