Old 11-29-2011, 07:18 PM   #1
MadMax
MadMax's Avatar
eBay Projector Headlights...
My stock lights are already clouding up due to the intense sunshine we get here in south-central Texas, and I think the projectors look pretty sweet. Are any of the ones on eBay any good?
I am considering a set, but recall the horror stories of them not being properly sealed or other problems. Is anyone on there selling some that are decent? Is the light output close to the stock units?
Firsthand experiences and recommendations would be appreciated!
Cheers! M2
Old 11-30-2011, 02:32 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Well assuming they're all the same ones you're talking about (the ones that use H1 bulbs), mine haven't leaked yet. The clear finish on them is doing good so far. I've only had them for a few months though.
Also, it rains a LOT where I live. So the fact they haven't yet leaked is a good sign.
Old 11-30-2011, 03:28 PM   #3
MadMax
MadMax's Avatar
That's the kind of info I'm looking for, thanks!
Cheers! M2
Old 11-30-2011, 07:03 PM   #4
boggydee
Drives: 2009 yaris 4dr hb
halo projector angel eyes
Anyone know if the ones on ebay would work on 2009 hb? Ive looked and it tells you that its good for 06-09 but somewhere here in this forums it said that the 09up headlights are different.... Can anyone help me out with this question?
boggydee is offline   Reply With Quote
Old 11-30-2011, 07:24 PM   #5
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
Yeah, they don't fit the 2009 bumper. Same thing with the taillights.
I haven't found any 09+ projector headlights like that.
Black_griffin6 is offline   Reply With Quote
Old 11-30-2011, 11:06 PM   #6
mario98c
mario98c's Avatar
Buy morimotos mini h1 projectors! Here are mine!
Cutoff
Old 12-01-2011, 07:40 PM   #7
boggydee
to mario.... would this work for hatch 09? do thy have a wesite I can check?
Old 12-01-2011, 07:54 PM   #8
mario98c
mario98c's Avatar
Yes it works in the Hb... The projectors are "plug and play" like the ones that garm sells. Here is the link. http://www.theretrofitsource.com/pro...oducts_id=3181
Old 12-02-2011, 10:26 PM   #9
boggydee
thanx mario that looks great! wat shroud did you use and bulb?
Old 12-02-2011, 11:34 PM   #10
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
^ cept those are retrofits. They require dremeling and dismantling of your headlight housing
Old 12-02-2011, 11:51 PM   #11
mario98c
mario98c's Avatar
I use the mini gatling shroud with cheap ebay 6,000k bulbs but I want morimotos 5,000k bulbs
Old 12-02-2011, 11:56 PM   #12
mario98c
mario98c's Avatar
In Hb is easy to do... in the sedan is a little more difficult because you need to trim the reflector housing for the projector can fit.
Old 12-03-2011, 01:10 AM   #13
boggydee
lol. but I think I might have a problem if I have to dismantle my headlight housing... Anyone can show me steps and pics how to do this? I have eyelids from MI and I've already repaired the eyelids twice because it kept cracking and I dont want to affect them... please help lol =)
Old 12-03-2011, 01:11 AM   #14
boggydee
I saw somewhere in this forum that you have to bake the headlight to dismantle them.. if this is true... my eyelids for sure will get wrecked since I put 3M clear plastic on them also
Old 12-03-2011, 02:53 AM   #15
rufnnek
rufnnek's Avatar
Drives: oliveMist
@mario98c
very nice HL
@boggydee,
we used heatgun and lot of patience in opening our HL. i try to look for pictures on how we did it. see my avatar for the finished product.
- LESS TALK, LESS MISTAKES...
- BATO BATO SA LANGIT ANG TAMAAN MAY GALIT
rufnnek is offline   Reply With Quote
Old 12-03-2011, 12:42 PM   #16
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Eyelids are pretty easy to remove. Just get a hair drying and warm up the adhesive and then geta razor blade and very carefully lift the adhesive.
Old 12-04-2011, 06:25 PM   #17
To the OP, you can dehaze your headlights using Plast-X. Then just keep waxing them when ever you wash your car. That should clean it up and prevent it from hazing over.
Or if you get new headlights, just wax them periodically. lol.
Old 12-04-2011, 09:03 PM   #18
Black Yaris
der Zeck
Black Yaris's Avatar
After you clean the haze I would recommend getting them sprayed with an automotive clear that has UV protection. This will prevent them from getting hazed again
eBay Issue - Your help needed *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 02-04-2011 09:18 PM
WTB: Gauge Cluster w/tach for HB cdydjded Willing to Buy by private party 12 06-09-2010 03:49 PM
Cheap eBay LED Strip vs V-LED Strip Kaotic Lazagna Cosmetic Modifications (Exterior/Interior) 1 03-18-2010 08:06 PM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
ebay intake: would you? thebarber Performance Modifications 7 12-03-2008 12:44 AM
