Old 12-02-2011, 02:31 PM   #1
basit701
Drives: Toyota Vitz (Yaris)
Toyota yaris OEM Speedometer + Tachometer HELP!!!!!!!!!!!!!
Guys i bought a Toyota Yaris (vitz) 1.0. The car cluster has only speedmeter no tacho. I want to ask that if i buy original cluster wth speedometer and tachometer would it will work with the same wiring. i have seen that both meters have same harness slot.
PLz help!!!!!
basit701 is offline   Reply With Quote
Old 12-02-2011, 03:34 PM   #2
To be sure, check the smaller of the two connectors on your car. Pin 15 should be a black wire, between a violet wire with a white stripe and a yellow wire. If that black wire is present in pin 15, then the wiring is in place to allow the tach to work.
Old 12-03-2011, 09:59 AM   #3
basit701
@. Ctscott I want to ask that when I start the car ABS light does not pop up unlike all other lights such airbag pop up and go away. Plz help what's the matter
Old 12-03-2011, 10:05 AM   #4
There are clusters for cars with and without ABS. Sounds like you got one for a car without.
Old 12-04-2011, 04:50 AM   #5
basit701
That means that my car is without ABS :( ????
Old 12-04-2011, 07:13 AM   #6
BLH
Drives: 2007 Yaris Sedan
Did the original cluster have a ABS Light that went On?
If the original one did light and the one you now have does not. You most likely got one that does not support ABS.
FS: CA 2009 Toyota Yaris OEM MP3 CD Player weedtank Items for Sale by private party 0 09-28-2011 05:59 PM
