Old 12-09-2011, 04:18 AM   #1
koklushkin
Drives: Yaris SCP90
Yaris SCP90 immobilizer
Hi! I`ve got Yaris SCP90 08 year and i want to install immobilizer myself but i need some help! Immobilizer i want to install on EFI coil + hood lock One problem i cant find EFI relay ! Can you help me please?
koklushkin is offline   Reply With Quote
Old 12-09-2011, 07:16 AM   #2
The EFI relay is part of the integration relay, which is the black chunk under the EFI fuse in the under hood fuse panel. The wiring from the ECM to the coil of it goes from the ECM connector (against the passenger side of the firewall) to the connector under the bottom of the integration relay.
The wire to the coil is the gray wire in pin 2 of connector 1A.
Old 12-09-2011, 12:38 PM   #3
koklushkin
Drives: Yaris SCP90
CTScott thanks for replay! Is there any diffrents between 1NZ-FE & 2SZFE (SCP90L-CHMGKW) engine control system?
Old 12-09-2011, 12:45 PM   #4
It is the same for the 1NZ-FE, 2NZ-FE, and 2SZ-FE.
Old 12-10-2011, 07:38 AM   #5
koklushkin
Drives: Yaris SCP90
I was thinking about place where to install immobilizer and came to this connection and the origin
Immobilizer relay is "NC" default and when protection switch is on "NO".
Won`t be a deadline for engine and ECM when protection will switch ON while engine runing? Protection is working on car movement. Or can advice me a better connection. Sorry for my english
Old 12-10-2011, 07:43 AM   #6
NO for protection and NC for normal operation is correct for that wire.
Persuade me to buy a Yaris! TONIZZLE General Yaris / Vitz Discussion 48 09-09-2011 11:31 AM
Best anti-theft strategies for Yaris without engine immobilizer? rtom General Yaris / Vitz Discussion 34 01-06-2010 01:56 PM
