Old 12-12-2011, 10:24 AM   #1
barryware
Info to Share
I replaced my water pump 2 weekends ago.. In doing so, I disconnected the battery to remove the alternator..
Once the job was complete (3~4 hours), I started the car.. took it for a quick drive to heat it up, get all the air out of the cooling system, and top off the radiator and reservoir tank after it cooled.
I noticed that for a while, the car would barely idle.. I have a scanguage II and the car would idle about 430 ~ 450 rpm (normal idle is 600~650 rpm).. It shook and rattled. To keep it lit at the stop lights, I would put it in neutral and rev it a bit. After a few miles, it was better but still not running right. I wasn't sure what was going on at the time but after a couple of days driving the car.. everything straightened out and the car never ran so well or smooth.
Unfortunately for me, the new water pump was defective (new.. not a rebuild). It was leaking around the shaft. I had to replace the water pump again last weekend.
The same thing happened in regards to the car not idling right, not shifting right, etc. after putting it back together and running it. Now two days later (maybe 100+ miles or so between test driving it and a trip to the office), it is again running and shifting as smooth as silk.. Maybe even better than when I first bought the car new.
I am pretty sure that the computer(s) in the car "learn" as they go but I was not aware that they would "forget" if the battery was disconnected.
I am going to make it a scheduled task to disconnect the battery and let it sit for a few hours a couple of times a year. I might suggest others do the same. As said, my car has never run so well & smooth and I am sure it is not my imagination.
2007 USA HB.
barryware is offline   Reply With Quote
Old 12-12-2011, 10:39 AM   #2
Disconnecting the battery for long enough to discharge the capacitors (> ~30 seconds) causes the ECM to reset the short term fuel trims.
With my Supercharger, I do it about once a week to prevent the ECM from learning how the extra fuel from the Blitz fuel controller richens the AFR. If I don't reset it regularly, the ECM adjusts the fuel trim enough that I starting running lean.
Old 12-12-2011, 01:05 PM   #3
mr_miles
Drives: 2013 Yaris
Oh wow, i had no idea they could "learn" like that. going to try this on mine and see if anything changes, lol.
Old 12-13-2011, 09:33 AM   #4
rick996
rick996's Avatar
Drives: 2010 5 door hatch w/5 sp man.
Thanks for the tip barryware. I'm going to give it a try.
rick996 is offline   Reply With Quote
Official Scangauge II Thread - Share your Data, Discuss Settings ,Problems, Findings! TRD_Yaris General Yaris / Vitz Discussion 183 02-01-2017 12:18 PM
NST (NonStopTuning) Short Shift Kit Info, Specs, User Data... NonStopTuning Performance Modifications 195 12-23-2011 12:44 AM
$1,600 Government Rebate on Fatt Batt Insulation or Solar Hot Water Systems Info. *MAD DOG* Australia 1 03-27-2009 09:44 AM
