Old 12-14-2011, 03:35 PM   #1
Captain Slow
My Face Is Ridiculous
Captain Slow's Avatar
Drives: 2010 Toyota Yaris 3dr LB
Widest tires for 15x6.5?
Really looking into getting some Konig Lightspeed wheels....offset is 38, size is 15x6.5
What's the widest tires I dare stick on those wheels to keep from rubbing at all? Keep in mind I'm going to do the TRD springs & shocks probably next summer.
Also, what would my 185/60/15 current tires look like on that setup? Would the 185s be too narrow? My tires still have lots of tread.
Captain Slow is offline   Reply With Quote
Old 12-14-2011, 05:05 PM   #2
How was this not covered sufficiently in your other thread?
(the one you got frustrated in and asked that it be closed)
Old 12-14-2011, 05:09 PM   #3
Captain Slow
because I was asking about 16x7s, not 15x6.5. I've decided to go with 15s to save weight.
Old 12-14-2011, 05:24 PM   #4
As I recall, you were asking about both 15's and 16's. The answer doesn't change, regardless.
Old 12-14-2011, 05:36 PM   #5
redglare45
redglare45's Avatar
Drives: 07 Sedan - 5 Speed Manual
I'm waiting for the widest on 15 x 5.5 thread. Then, I have a feeling widest 14 inch rims will have a couple of new threads, just for sh!ts & giggles.
redglare45 is offline   Reply With Quote
Old 12-14-2011, 05:38 PM   #6
Captain Slow
no I had settled on 16x7 in the other thread, now I've decided on a different rim size.
please don't mistake this as sarcasm, I'm genuinely interested, how does the answer not change?
wouldn't a different rim size require a completely different tire size? i remember the link from the other thread so I'm cool with figuring out what tire size to use to achieve a similar diameter to factory (so as not to throw off the speedo), but it's the widths I know nothing about. I understand I will need xxx/60/R15 to maintain the same diameter.
I do know that my current 185s will fit 15x6.5 wheels, but they will be a tad stretched, what I don't know is what width I would be able to go up to without rubbing (especially once lowered on TRD suspension).
Old 12-14-2011, 05:41 PM   #7
Correct. So 205/60/15.
Done.
Old 12-14-2011, 06:50 PM   #8
Captain Slow
cool, now if only I understood HOW you know that. is it from personal experience or is there some magic formula I don't know about? like I said I get the whole outer diameter thing, but how do you know about widths without trial and error?
thanks for the education!
Old 12-14-2011, 06:58 PM   #9
1010tires.com
Find the tire size calculator
Old 12-14-2011, 07:00 PM   #10
You don't want more than 50mm wider tire than rim, +/-.
6.5" is about 160mm....so Max width would be 205 or 215(((((
Old 12-14-2011, 07:11 PM   #11
Captain Slow
ah ok, makes sense. just really, REALLY didn't want to buy a combo and then have it rub when I do the TRD suspension. zero is the only acceptable amount of rub to me, some setups might look nice, but it's just not worth it.
Old 12-15-2011, 01:47 AM   #12
Pure experience, including mistakes.
Remember to support your YW vendor (me) when comparing prices for wheels and/or tires.
Thanks a lot barber -- not.
Old 12-15-2011, 05:07 AM   #13
Take it easy garm....I said use 1010tires for the calculator...
Old 12-22-2011, 12:26 PM   #14
Blue Beast
Drives: 2010 Yaris 3 door hatchback
I did the TRD suspension, lowering springs, shocks and sway bar first with 15x6.5 rims initially running the GY 185/60 15 stock rubber and performance was great. I just switched out rubber running 205/55 15's and no problems rubbing and much improved looks and handling. I just posted new tire and wheel pix on "post pictures of your aftermarket wheels and tires here" thread if you care to see this set up. One of the four pix you can see the stock Goodyear LS 185's on 15x6.5 rims.
MI Crank Pulley
DC Sports Header
TRD Stainless Sport Exhaust & TRD HP Air Filter
TRD Sport Shocks, TRD Lowering Springs, TRD Rear Sway Bar
MOTEGI RACING MR121 RIMS 15 x 7, Kumho Ecsta RSX 205/55/15
TWM Short Shifter, Base & Cable Bushings, Weighted Hybrid Shift Knob
VG Shark Fin Antenna, De-badge factory emblems, TRD Black Chrome Badge
Blue Beast is offline   Reply With Quote
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
2007 Yaris bad tires weaver615 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-27-2010 07:21 AM
Widest tires I can get for 15 stock wheelies iwantayarisnyc Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 12-08-2008 09:14 PM
