Old 12-17-2011, 05:05 PM   #1
bronsin
bronsin's Avatar
Fuse Fix
Years ago there was a car called the VW Beetle (no not the new beetle) It had fuses 1) you could look at in the fuse box and see if they were blown 2) if the fuse was bad you could get it out with your fingers.
Fast forward to today. Cars are better, right? Well...maybe. But the freaking geniouses who made todays cars made them with fuses you cant get out of the fuse box! And until you get them out you cant see if theyre blown! This is better? Is it huh? Oh I know they give you a fuse puller in the fuse box but sooner or later its going to get lost and then you are SCREWED!
So do this. Epoxy two fuses back to back. Now you can get the fuse in and out without a puller! I did it to the 7.5 amp ac fuse so I can turn off the ac in the winter so it does not come on when I turn on defrost.
YAY!
30A Power Fuse Instrument Panel Location? Kioshi DIY / Maintenance / Service 16 03-31-2013 06:53 PM
Thank You All! Found a simple fix, for what seemed like doom. Mattneto15 DIY / Maintenance / Service 4 11-13-2011 11:21 AM
radio fuse Nodrog In Car Entertainment + Electronics (audio / video / alarm) 2 11-10-2011 06:10 PM
fuse box for fuse for brake lights drew999 General Yaris / Vitz Discussion 2 01-19-2010 02:38 PM
2009 empty, usable fuse location? schleppy In Car Entertainment + Electronics (audio / video / alarm) 3 04-23-2009 12:07 PM
