Old 12-18-2011, 09:38 PM   #1
randydid
Drives: 2012 Yaris SE Five Door
Speedometer off?
Hi,
I just put 383 miles on a tank of gas which took 10.22 gallons to fill. That equates to about 37.5 mpg calculated. The gauge reports 33.8. In my neighborhood and other places we have those speed signs that tell you how fast you are going vs. posted limit. My SE's speedo reads 2-3 mph faster than the signs are reporting. Has anyone else noticed speed descprentcies like this? Yes, I have the stock 16's with OEM rubber.
randydid is offline   Reply With Quote
Old 12-18-2011, 10:02 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
My speedo was off with the stock 185/60/15's. With 205/50/16's, my speedo is dead on.
Old 12-19-2011, 10:02 AM   #3
traveller
Drives: Anything but Toyota
Here in the U.K. there's a 10% allowance for speedo accuracy. Usually they read a bit high anyway, which I prefer as that reduces the chances of being over the limit!
Yours is possibly indicating that bit more anyway.
traveller is offline   Reply With Quote
Old 12-19-2011, 10:29 AM   #4
KentSzabo
KentSzabo's Avatar
Drives: 2012 Toyota Yaris L, 5 speed
I have nearly 4100 miles on mine now, and I can tell you the speedometer/odometer is accurate, but the problem is with the Average Fuel economy calculation. On level ground and going uphill it is accurate, but going downhill is a completely different story. The AVG Eco going downhill can not exceed a mileage of 99.9, when in fact the vehicle may be getting anywhere from 120 to 160 mpg during those downhill cycles. Therefore, the entire average computed is skewed downward anywhere from 1 to 5 mpg depending how much hilly terrain you are driving over.
This is evidenced at fill up time if you keep your odometer figures from last fill up. Calculating yourself is the only way in these vehicles with average economy calculators to verify your true mileage. On my 2000 Caddy Eldorado it also has one of these calculators, but it can't exceed 70 MPG going downhill and exhibits the same problem as the Yaris's calculator.
2000 VW Golf TDI, 5 Speed, 48 MPG
2000 Cadillac Eldorado ETC, Auto, 23 MPG
2004 Dodge 3500 Auto, Dually, 6" Lift, 36" Tires, 4" Dual Stacks, Predator, 20 MPG
2012 Toyota Yaris L, 5 Speed Manual, 46.4 MPG
KentSzabo is offline   Reply With Quote
Old 12-19-2011, 11:24 AM   #5
A-Dingo-Ate-My-Baby
Drives: yaris
get a scangauge and an GPS unit and program the scangauge to display actual
speed (use the GPS for 30 minutes above 75MPH to get actual reliable moving speed) no matter what the car speed pickup says.
you can dial a percentage offset and get scangauge to read dead-accurate
miles and speed regardless of tire size
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Speedometer Accuracy? YarisPete DIY / Maintenance / Service 37 11-29-2013 02:00 PM
Speedometer david.gartee1 General Yaris / Vitz Discussion 5 07-15-2011 02:32 AM
speedometer walt101786 Cosmetic Modifications (Exterior/Interior) 0 10-09-2010 09:03 PM
09 Sedan Speedometer with Tach MT Low Miles. A1phazu1u Items for Sale by private party 17 05-13-2010 05:08 AM
No speedometer or tachometer lights during day cdavidhess DIY / Maintenance / Service 20 06-30-2009 10:38 AM
