Old 12-22-2011, 04:26 PM   #1
advocate
Drives: car
title goes here
message goes here
Old 12-22-2011, 04:58 PM   #2
There are a few places that you can send them to for reprogramming (do a google search for odometer reprogramming). It turns out that you actually have to remove the EEPROM where the data is stored, reprogram it, and solder it back onto the board.
I have monkeyed around with it a bit with some of my spare clusters. I was hoping to find that I could clip a piggy back socket on the chip and reprogram it in place, but unfortunately that doesn't work.
Old 12-22-2011, 07:34 PM   #3
$350 Ouch! The process is actually fairly easy (desolder the 8 pin EEPROM, run the mileage through a magic program that generates the checksum to go along with that value, reprogram the EEPROM with the modified data, and solder it back down).
It is kind of a shady thing though, as theoretically here in the US it is illegal to modify a cars odometer. If the odometer is modified or replaced it must be documented (and that info even appears in a carfax on the car).
Old 01-08-2012, 01:23 PM   #4
No. They can't be switched from KM to Mi.
VALVE ADJUSTMENT INTERVAL jemmah DIY / Maintenance / Service 7 10-12-2016 10:13 AM
clutch adjustment 1krzys DIY / Maintenance / Service 0 09-01-2011 03:10 AM
Adjustment to the upper shock mounting point? Goose Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 06-07-2010 03:41 PM
Yaris Odometer infonote General Yaris / Vitz Discussion 9 12-09-2008 02:39 PM
Has anybody Changed the Odometer in the HB pp.sweet DIY / Maintenance / Service 2 08-21-2007 06:00 AM
