Old 12-31-2011, 05:39 PM   #1
ciscobear
Drives: Toyota Belta
Part number for Inner chrome door handles?
Do you guys/gals have the part number requested ? It seems the 2011 Yaris sedan came with them standard and also the Japanese 2010 Belta G grade.
ciscobear is offline   Reply With Quote
Old 01-14-2013, 05:56 PM   #2
ciscobear
ok so for anyone that's interested. I got them:
69205-52150-B1 - Chrome inner door handle Right hand
69206-52150-B1 - Chrome inner door handle Left hand
Above for vehicles with this interior
Old 01-14-2013, 06:04 PM   #3
ciscobear
69205-52150-E1 - Chrome inner door handle Right hand
69206-52150-E1 - Chrome inner door handle Left hand
Seems to be for interiors with this colour:
Old 05-24-2013, 12:25 AM   #4
ciscobear
So I did the actual install today. Bought some non-genuine ones from Rockauto at 10 a piece as opposed to the dealer's $30.
Took about 5 mins a side really, just being extra careful not to scuff the interior panels.
Old 05-24-2013, 03:46 PM   #5
jcboy
Drives: Sedan 07
how did you remove them? i understand you had to take the door interiors off? i just dont have them in the Service Manual i got from YW.
thanks man!
Old 05-25-2013, 10:28 AM   #6
ciscobear
They are two screws you need to remove, the one seen in the pic, the one in the inner piece by the power window switch. Remove the plastic piece behind the mirror, pops out and remove the plastic push pin just below it.
Pull up the power window section and remove window switch harness. Then feel along the bottom of the panel and remove the door panel, pull gently and you will hear them popping out. Voila panel off.
Remove the two rods for door locking on the inner handle. Then ease the inner handle up from the back and work it out. It's very easy to do.
Old 05-26-2013, 06:26 PM   #7
jcboy
Drives: Sedan 07
i got it. thanks for the detailed response. Now all i have to do is find the cheap ones that go for $10-ish as opposed to our $30-ish price tag at the stealerships. (around PhP 1,200.00)
Thanks CiscoBear!
Old 10-27-2013, 01:29 AM   #8
deathwisher
Drives: 2007 Yaris Sedan
Just curious, are these just for the fronts or are they the same part numbers for the back doors as well?
deathwisher is offline   Reply With Quote
Old 10-27-2013, 06:57 PM   #9
ciscobear
Same for the back doors as well. Thanks for reminding me. I need to swap those out lololol
part number for Antenna cr.chango DIY / Maintenance / Service 3 11-13-2009 02:40 PM
So there is no part number for the LED tail light? caineroad General Yaris / Vitz Discussion 3 08-17-2009 08:09 PM
Anyone know the part number for this? mrbond Cosmetic Modifications (Exterior/Interior) 15 03-30-2009 01:45 PM
Part number on rear skirt needed, who works at Toyota? Danish Yaris DIY / Maintenance / Service 0 02-07-2009 05:52 AM
Anyone know the dealer part number for the 09 S kit 808yarisLB New YARIS Purchase Forum 5 12-08-2008 10:38 PM
