Old 01-01-2012, 05:41 PM   #1
KevD
Drives: Blue 2007 3dr 5spd
"!" brake warning light on
First off, happy new year!
This summer is pulled my main ABS fuse to disable them. This caused the ABS warning light to come on as i expected. Recently though, the "!" brake warning light has lit up. After doing some research, it sounds like a wheel speed sensor problem. Winter driving has probably gummed it up...
The other concern i have is when i get out of the car after driving to work (approx 30 mins) the passenger rear wheel smells like burning rubber/ burning brakes/ burning brake fluid (it's hard to determine exactly what the smell is). Almost like it's dragging the brakes. Fluid isn't low and the car doesn't seem to be held back like if the brakes were stuck on.
I'm wondering if this could be related to the warning lights!? Anyone have this happen?
Any info would be awesome. Thanks a bunch.
KevD is offline   Reply With Quote
Old 01-02-2012, 07:59 AM   #2
sex
sex's Avatar
Drives: 09 5DR
Re. burning smell: Have you pulled the wheel off and turned the drum to see if the brakes are indeed stuck?
Old 01-02-2012, 01:17 PM   #3
MUSKOKA800
MUSKOKA800's Avatar
Have you checked your manual to determine what the (!) symbol means. It does come on when my parking brake is engaged. Check that the lever isn't slightly raised (a notch or two).
Old 01-02-2012, 08:45 PM   #4
KevD
Haven't taken the wheel off yet, that will be this week... E brake is definitely off. The light is out again (for now..). I had washed the car a few days prior to the light coming on... Thinking maybe some crap got into the wheel sensors??
I will take the wheels off this week and let you guys know what a find.
Thanks!
HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! mizhgolightly DIY / Maintenance / Service 45 05-03-2022 02:59 PM
one brake light out xartrax DIY / Maintenance / Service 3 01-27-2011 12:40 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
