Old 01-02-2012, 09:53 PM   #1
ttr125fan09
ttr125fan09's Avatar
Drives: yaris
weapon r throttle controller?
what does this do?
pros and cons?
couldnt find anything on it
http://www.andysautosport.com/toyota...hips/weapon_r/
ttr125fan09 is offline   Reply With Quote
Old 01-03-2012, 12:16 AM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Try a search. Here, saved you some time. The whole product is basically the same - just badged as different names.
NTD 3-Drive Throttle Controller, Pivot, i-Throttle, etc.
Blitz Throttle Controller (no longer made?)
Because the Yaris is "drive by wire", there is no physical cable connected from pedal to throttle, the amount of pedal pressure is electronically calculated in the ECU then a signal is sent to open the throttle. Many experience a slight lag in throttle response when stepping on the gas pedal. Throttle controllers can improve on that by minimizing that lag.
Old 01-13-2012, 07:12 AM   #3
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
is "dirve-by-wire" same as electronic throttle? that's wut i understand it is
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 01-13-2012, 01:09 PM   #4
^ Yes, exactly. As opposed to "drive by cable" or "cable throttle".
Old 08-05-2013, 12:31 PM   #5
oohcory
Oohcory
Drives: 12' Yaris 2dr Liftback
Send a message via AIM to oohcory
I know this threads a tad bit old, but would anyone know if the ithrottle will work with the 3rd gen?
oohcory is offline   Reply With Quote
Old 08-05-2013, 01:37 PM   #6
The 3rd gen uses the same accellerator pedal connector and throttle body connector (with the same pinouts) as the 2nd gen, so I would say yes.
Old 08-05-2013, 02:16 PM   #7
In stock too.
3 Drive Throttle Contoller by NTD Sabretooth Performance Modifications 31 10-07-2010 12:12 PM
F/S iCocept AT-Power Throttle Controller 1NZYaris1 Items for Sale by private party 5 06-15-2010 07:48 PM
Group Buy for NTD 3Drive throttle controller twpanson Sponsors Classifieds Area 35 11-17-2009 10:18 PM
Testing water on 3 Drive Throttle Controller for Yaris (Vitz) twpanson Performance Modifications 57 10-31-2009 02:07 AM
Blitz throttle controller 808_Yaris Performance Modifications 43 10-22-2009 04:36 AM
