#1 |
![]() ![]() Drives: 2011 Yaris 3-Door Hatch white Join Date: Feb 2010
Dynamat - Any fuel issues?
Heya gang.
ill be installing dynamat into my car as my audio system build progresses, and want to get rid of as much road noise as possible. Being that dynamat can get quite heavy in significant enough amounts, I ask if anyone has noticed a drop in fuel efficiency or any other negative factors aside from the cost of the dynamat? :) |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
to reduce the noise to the noticeable level you would need at least 50-60 kg of dynamat.. which will sure be noticeable for fuel efficiency - expect to lose some mpg
#3 |
Mr. 155 and climbing
Drives: Seriously Modded 07 Sedan Join Date: Jun 2006
additional weight will always hit you in small cars either performance-wise or mpg-wise. You make trade offs really. For example going boosted with a turbo. You will NEVER maintain the same mpg rate you did before. With this car you can still have great mpg, but it WILL take a hit. If I remove my sub box even, that being 50lbs I gain even just 1 mpg. That is 10 mile miles per tank...ten tanks that is 100 miles...it adds up. You just need to decide what is more important to you.
Team Tiamat Racing on Facebook Youtube Channel: Team Tiamat Racing Class record holder in Land Speed @ 154.5mph for 1.5 mile and 145.5mph in the mile in the F (2.016 to 3.014 L), G (1.524 to 2.015 L), and H (1.016 to 1.523 L) classes. |
#4 | |
Audio Junky
if you are really serious about about reducing rattles, and have plenty of time, i'd recommend putting multiple gallons of the liquid deadener on the floor boards and firewall as that stuff adds weight but also hardens so it adds a bit of rigidity too which mat doesn't do (mat is just weight). |
#5 |
FYI...
I have more than 200 pounds of extra weight from many CLD Tiles, Mat, and about 100 sq feet of MLV, ... I still get 43.2 mpg in summer and 40.2 mpg in winter. D.
. CLA 250, 4MATIC |
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| fuel guage issues | bonusjonas | DIY / Maintenance / Service | 4 | 12-07-2011 08:52 AM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
