Old 01-16-2012, 01:08 PM   #1
Nips
Nips's Avatar
Drives: BMW 3 Series M Sport
Centre air vent part number
Hi guys, does anyone know the centre air vent part numbers, I require the vents and the black part the vents sit in, all these parts sit behind the radio surround
Thanks
Nips is offline   Reply With Quote
Old 01-16-2012, 01:26 PM   #2
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
55670-52010-C0 for black
55670-52010-B0 for gray
OTA'sTOY is offline   Reply With Quote
Old 01-16-2012, 01:31 PM   #3
If you PM me your VIN, I can look it up in the European EPC. There are a couple of different color codes, so I would need to VIN to verify which your car uses.
Old 01-16-2012, 01:33 PM   #4
The ones listed above would be correct for a Japanese built one, but not for a France built one.
Old 01-16-2012, 01:34 PM   #5
OTA'sTOY
OTA'sTOY's Avatar
Drives: '10 5dr
or you can pull out yours and locate the part # on it
Old 01-16-2012, 01:53 PM   #6
Nips
Nips's Avatar
Thanks Scott will PM you in a mo
Can't get it off the original because it's half gone, it has two devices in the air vents half the vent was cut away
Old 01-16-2012, 02:24 PM   #7
Yours was built in Japan and the EPC is showing the gray (55670-52010-B0) as being the correct color code for your car. That part number contains the entire center vent assembly that snaps into the back of the radio surround.
Old 01-16-2012, 02:35 PM   #8
Nips
Nips's Avatar
Thanks Scott for your help, much appreciated
Help with part number or name. thorasaurus DIY / Maintenance / Service 2 09-29-2011 11:43 PM
driver rails part number help joeharth DIY / Maintenance / Service 1 11-13-2009 01:44 PM
Part number for VIP Alarm mehullica In Car Entertainment + Electronics (audio / video / alarm) 5 10-27-2009 08:00 PM
Finish Sedan S Intake, Paint Caliber, Air Vent Lights jamal1984 Performance Modifications 9 03-12-2007 11:57 AM
