Old 01-19-2012, 08:05 PM   #1
shameer_k
Drives: yaris sedan
Headlight leveling motors
Has anyone ever installed headlight leveling motor to their normal headlight?
shameer_k is offline   Reply With Quote
Old 01-20-2012, 04:05 AM   #2
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Seems like a lot of work and expense to adjust a mechanism that usually only needs to be adjusted once in the lifetime of the car.
If your lights are a bit out of alignment its not hard to turn the two adjusting screws..
Have Yaris will travel..
Old 01-20-2012, 12:59 PM   #3
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
The JDM Yaris headlights on certain packages have auto leveling headlights.
I also dont think anyone has done this yet because....we might need the ECU for this? Maybe CTScott can chime in.
I know some Toyota cars have manual adjusting headlights..the car i rented out when i was in Japan had it. Very similar knob to the cluster illumination knob/wheel.
Old 01-21-2012, 08:19 AM   #4
shameer_k
Drives: yaris sedan
My car came from Japan so I was wondering if it was an easy addin
Old 01-22-2012, 10:35 AM   #5
Lil Abner
Drives: 2009 3dr LB Manual
I had the manual level adjustments in my 2000 Celica GT-S with the OEM HID package. I have the motors on my test bench, and the circuit to make them work is very simple. Basically an adjustable resistor (potentiometer) and some other parts. After taking our OEM headlights apart, I noticed the OEM Toyota motors would fit very easily.
But why didn't I do it? Sure, it would be cool to have. But I don't change what I load much, so it would have just been a waste. But I can tell you, it is possible.
Old 01-22-2012, 11:37 PM   #6
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
we would need to get the Vitz motors. How big are the motors of tge Celica? and possible room to fit in ours?
Old 01-23-2012, 01:55 AM   #7
BluYrs
ヴィッツ ドライバー
BluYrs's Avatar
Drives: 2006 3d 1.0 Linea Sol
Mine (IMHO all EU market Yarii) has manual headlight adjustment. You can see part of the switch here in this pic. I believe you guys have the instument panel illumination switch there (which we don't get).
The blue one
Old 01-23-2012, 01:33 PM   #8
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
pic of..... mirror switch?
huh
OTA'sTOY is offline   Reply With Quote
Old 01-23-2012, 01:43 PM   #9
thetut
Drives: 2007 4dr sedan
I think he means the switch to the right edge of the picture.
thetut is offline   Reply With Quote
Old 01-23-2012, 02:16 PM   #10
bronsin
bronsin's Avatar
My ST1300 motorcycle has motorized headlite up and down.
I never use it.
I did have to adjust it with the screw provided.
Yes it has a screw adjuster even though its motorized. For some dumb reason the travel used by the motor doesnt cover the entire range...
Old 01-24-2012, 02:04 AM   #11
jambo101
jambo101's Avatar
What are you guys doing to get your headlights out of adjustment so often that electric motors are being considered to keep them in alignment?.
Dont think i've needed to adjust a headlight on any of my cars in 20 years..
Old 01-24-2012, 02:45 AM   #12
BluYrs
ヴィッツ ドライバー
BluYrs's Avatar
Correct.
This is for height adjustment (leveling) to compensate for the front of the car tilting upwards when the boot is loaded (thus aiming the headlights to the sky and oncoming drivers). The electric motors allow to temporarily lower the light beams so they light the area of the road they're supposed to.
The blue one
Old 01-24-2012, 08:17 PM   #13
Lil Abner
You might want to look at this thread. This guy uses the same motors that I have. Although, he points out that they are tough to find. Although, I've seen similar ones on eBay for different cars.
http://www.tacomaworld.com/forum/2nd...-retrofit.html
Old 01-24-2012, 11:45 PM   #14
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
I looked through those Tacoma forums, and those DIY work looks very clean.
And i didnt know the Sienna XLE had the manual controls for the motors.
Thank you for the link.
So whos up for this project?
Old 02-05-2017, 06:17 PM   #15
Jerkratt
Jerkratt's Avatar
I can get a used set of headlights with the motors.. But want to know how to use them.
"It hurts more when its wet"
Old 02-09-2017, 09:10 PM   #16
B.B._07
Drives: 07 5dr
In Europe height adjusting headlights are mandatory for all cars. To get a European set of lights to work on a NA market car you would need the lights with the motors and the interior switch along with wiring to control them. You would have to modify at least some of the to the wiring to the lights as i really doubt it's prewired in the car.
Old 02-09-2017, 10:08 PM   #17
enviri
enviri's Avatar
Drives: 2010 Yaris
My headlights have those, but I didnt connect them when the OEM HID swap was done.
its like the dimmer for the lights on your dash.
the motor is where the up/down adjustment is. no clue about the wiring. I cant imagine it being complicated. (up, down, +, -[shared?]) or (+up, -, +down, then interior with the same with extra pin for illumination)
edit: 84152-52080 is the leveling adjustment in the interior. It goes right next to the side mirror adjustment switch.
Old 02-09-2017, 11:30 PM   #18
David C
Drives: White '07 3dr LB
I've always wondered what the blank space next to the side mirror adjustment was ! Even on the latest generation Yaris, the blank space is still there. Now I know something about the Yaris my dealership doesn't :p
Envoyé de mon iPhone en utilisant Tapatalk
David C is offline   Reply With Quote
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 04:13 AM
Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison CTScott DIY / Maintenance / Service 54 02-14-2011 08:58 AM
How To Smoked Sedan Headlight -DIY zulhizainL902S DIY / Maintenance / Service 26 01-14-2011 02:12 AM
Glassylite Headlight Restoration Kit TEHxFALLEN V1.2 Photo-Video-Media Gallery 1 07-03-2010 12:51 AM
HELP! I detailed my interior, and now having a headlight issue! Astroman DIY / Maintenance / Service 4 06-08-2010 06:51 PM
