Old 01-20-2012, 01:04 AM   #1
A1phazu1u
A1phazu1u's Avatar
Drives: Black 07 Toyota Yaris Sedan
H4 120 smd led....?
Ebay find
What do you think?
Will it shine brightly?
Will it require a ballast?
Is it worth it?
http://www.ebay.com/itm/2-X-Car-H4-1...item1e6a4ee702
A1phazu1u is offline   Reply With Quote
Old 01-20-2012, 01:09 AM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
It won't need a ballast, but it will also produce practically no useful light.
Old 01-20-2012, 01:12 AM   #3
A1phazu1u
A1phazu1u's Avatar
how so about the light producing part?
Old 01-20-2012, 01:15 AM   #4
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
LEDs don't produce very.. illuminating light. They are bright when you look at them, but their light doesn't cast about as well as a regular incandescent bulb or HIDs
Old 01-20-2012, 01:25 AM   #5
A1phazu1u
A1phazu1u's Avatar
what about when projected through a a half dome type lens? like projector headlights?
Old 01-20-2012, 02:34 AM   #6
Yeah, unless you get expensive, quality LEDs, I wouldn't be using LEDs for headlights. The ones you posted are probably going to end up being crap. I never had much luck with LEDs on eBay.
Old 01-20-2012, 03:27 AM   #7
SAV912
Pirate Yaaaaris
SAV912's Avatar
At less than $5 for a pair, they're undoubtedly useless.
LEDs for sidemarkers and turnsignals is one thing, but headlights have reflector bowls. The glow of an incandescent light is a gradual fade from dark to light. LEDs produce light in very straight and very narrow beams. That fact alone will allude to them not illuminating the road very effectively.
If you see the lenses on the high tech LED headlights on the Toyota Prius, Audi R8, and so on, they all have little projectors, and they need to have them. The LEDs behind those projectors also aren't dozens of tiny little diodes either. They're big. So while I'm curious to see how that would look, I doubt they would be any more useful than sticking candles in your headlights and using them to light the way.
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY LED Strip under the door panel charleschia1986 DIY / Maintenance / Service 19 11-05-2011 07:49 PM
Green LED Dome Light and Underdash LEDs Installed fnkngrv Cosmetic Modifications (Exterior/Interior) 11 08-20-2010 12:38 PM
LED Strip Lights ecmiyake DIY / Maintenance / Service 0 07-22-2010 10:32 PM
Interior LED Ricey Problem xbr3akd0wnx Cosmetic Modifications (Exterior/Interior) 10 05-06-2010 08:50 PM
