Old 01-23-2012, 05:14 AM   #1
whiteghetto
whiteghetto's Avatar
Drives: '07 blazing blue hatch
Trailer and Springs
Hello all :)
Thanks for all your past help.
I have a, hopefully, quick question.
I have a set of Megan springs waiting for spring to get installed.
I plan on getting a hidden hitch and small trailer.
Will the hitch/trailer work with the springs? I am concerned about bumper clearance.
-- John
2007 HB Blazing Blue
whiteghetto is offline   Reply With Quote
Old 01-23-2012, 08:12 AM   #2
Not sure I understand why you're concerned about bumper clearance just because your car will be sitting 1.5 inches lower.
What I would recommend is this. If your source for the Hidden Hitch sells the receiver with or without the draw bar, opt for without. The provided draw bar will not place the ball at the correct height. Install the receiver, then buy the draw bar seperately once you determine how much lift you will need to have the ball positioned properly relative to the trailer tongue.
Old 01-23-2012, 09:01 AM   #3
whiteghetto
I am worried the bumper will be to low for the hitch to be usable.
Though, I dig your idea and will run with it. I will just get the hidden hitch first. If all is a fail, it is still a rear connecting sway bar. :)
Old 01-23-2012, 09:42 AM   #4
I'm running a Curt hitch with Megan springs. No issues. Since a hitch is mounted to the frame, springs do not affect its location relative to the bumper.
Old 01-23-2012, 10:07 AM   #5
whiteghetto
A little bit of real world advice helps qualm the worries.
Old 01-23-2012, 10:54 AM   #6
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
*If* for some reason you find the hitch sits too low, pointing the nose of the trailer too steeply towards the ground, you can always remove the ball and flip the bar over and re-install the ball. It will elevate the ball to compensate for the lower vehicle.
From this:
To this:
-Type 07 FFL-
My odometer 03/11
Old 01-23-2012, 11:45 AM   #7
matthewai
matthewai's Avatar
Drives: it is kinda stock
i have a question to (rather than make a new thread) sorry
but would something like this (tow basket) fit on a sedan or is there no connection under the read bumper ?
(i know this one is on an suv)
thanks
Old 01-23-2012, 12:38 PM   #8
Yes you can. However, in my case, the drop bar that shipped with my hitch receiver is too low in normal position, too high flipped. With the lowering springs, and my trailer (they differ slightly from one to another) a zero drop bar worked best.
Old 01-23-2012, 08:55 PM   #9
MUSKOKA800
MUSKOKA800's Avatar
thanks
A basket would work with a sedan and aftermarket receiver (discussed above) however I've yet to see a basket for a 1 1/4" receiver. All I've seen are 2". An adapter might be available???
Old 01-24-2012, 08:23 AM   #10
1.25" do exist. Considerably lighter duty than the one pictured above. That thing looks like the work platform on a hydrolic scaffold.
http://www.etrailer.com/dept-pg-Hitc...nch_Hitch.aspx
Old 01-24-2012, 01:38 PM   #11
mazilla
advocatus diaboli
mazilla's Avatar
This is the basket my IT guy rocks on his LB...he also has a trailer he uses to haul small stuff, office chairs, etc.
Sorry for the thumb... :)
-Type 07 FFL-
My odometer 03/11
Towing with my Yaris Cortland Yaris User Photo-Video-Media Gallery 12 07-06-2010 01:07 PM
