Old 01-24-2012, 07:47 PM   #1
I PHANT0M I
Drives: 2010 Toyota Yaris
My new 2010 Yaris seems slow
It seems slow off the line, reason i say this because my Fiance 2008 Yaris is fast of the line it seems like i have to really push on the pedal to get it going...
Anyone have any ideas what could cause this?
so i can take it to the dealer and see if they can check if there is anything wrong with it
i use 91 octane Fuel if that means anything.
Thank You!
I PHANT0M I is offline   Reply With Quote
Old 01-24-2012, 08:28 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
The engine is designed for 89 octane. Using 91 will not:
-Yield significant power gains, if at all
-Get you better fuel economy
-detonate properly (the compression ratio for use of 91 is different then what the 1nz-fe is made for)
Is your car auto or manual?
Old 01-24-2012, 09:19 PM   #3
I PHANT0M I
Its Auto, the only gas available in my area is 85 87 91
Old 01-24-2012, 09:57 PM   #4
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Oh man, maybe that explains the marginal gas mileage I've been getting since I bought mine last year. I had a coupon for $0.50 off per gallon, so I "splurged" and filled it up with 89. Goes like stink in first, gets up to highway speeds with the quickness.
Old 01-24-2012, 11:09 PM   #5
Hershey
Maybe the trottle body needs a cleaning . Try a few tanks with Techron and 93 octane from Shell or other major gas company . If you do , let us know if any improvement .
Old 01-24-2012, 11:48 PM   #6
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Or the OP can just take out the intake and clean the throttle body and save money from repair shops.
Old 01-25-2012, 12:20 AM   #7
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Is your other hal's ride an auto as well? Is one a sedan and one an LB?
Old 01-25-2012, 07:18 AM   #8
1nzfe engine is designed for 87 octane....not 89
what wheels/tires are on the car? a heavier setup would make it feel sluggish
maybe check the spark plugs? air filter? maf?
Old 01-25-2012, 08:46 AM   #9
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
My bad.
Old 01-25-2012, 08:46 AM   #10
I PHANT0M I
Alright i'll surely do that how many times do you think i should do that? Once or twice?
Old 01-25-2012, 08:47 AM   #11
I PHANT0M I
Its a 15inch Yokohama tires
Old 01-25-2012, 11:53 AM   #12
Hershey
Few tanks in a row .
Old 01-25-2012, 12:57 PM   #13
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
I blame the e-throttle...
It seems to adapt to driving style...when i drive aggressive it quickens up a little bit...when im driving like im 87 years old to save gas its dull and delayed
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 01-25-2012, 05:02 PM   #14
nemelek
DWEED
nemelek's Avatar
Have a real race. See if the car really is slower or if it only seems that way.
Old 01-25-2012, 05:44 PM   #15
mryaris
Drives: 2010 Carmine Red hatchback
Just an FYI......high altitude areas (like Colorado) use lower octane gas because in this stratified air, 85 octane behaves like 87 octane.
This always confuses people who visit or just move here because they have always been told that 87 is the minimum octane rating they should use and they wind up spending more than they need to. In reality, 87 octane up here is like 90 octane at sea level. So when you fillup in the mountains use 85 octane! :)
mryaris is offline   Reply With Quote
Old 01-25-2012, 07:44 PM   #16
X2
I thuroughly enjoy my cable throttle for consistency
Old 01-25-2012, 11:19 PM   #17
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
The auto Yaris is quite possibly the slowest production vehicle in the states
Old 01-25-2012, 11:59 PM   #18
Mead
Drives: BSP Yaris LB 2007
+1
Mead is offline   Reply With Quote
2010 yaris suspension advice??? evilekhatch Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 03-16-2010 09:56 AM
