Old 01-29-2012, 02:30 PM   #1
DirtyHarry
Drives: Yaris 1999
Stuck Back Wheel
Hello to the community!
I have a very old Toyota Yaris (1999 model, purchased in 2000), that did not give me any troubles until this year. I use to do Toyota service once per year, usually.
Anyhow, since the beginning of January, due to snow, I did not use the car and left it parked. Every day I turned on the engine for a few minutes, just in case.
In the past two days I tried moving the car again, but whenever I try to accelerate, it feels like one of the back wheels (or both, difficult to say, but it seems to be it is the rear left one) seems stuck, as if the handbrake was on. Also, the handbrake seems to be very very hard when I try to pull it up, so I suppose it is not able to fully disengage itself.
Is there something I can do myself before calling a (very expensive here in ICeland) two truck? Anything I could try? My finances are terrible right now and it is difficult to find the hundreds of dollars it will cost to handle the matter.
Thanks everybody!
DirtyHarry is offline   Reply With Quote
Old 01-29-2012, 02:32 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
I suggest jacking up the rear of the car, releasing the handbrake and try to spin the wheel yourself. It shouldn't give too much resistance, but if it does then something is definitely wrong back there.
Old 01-29-2012, 02:53 PM   #3
DirtyHarry
Drives: Yaris 1999
Thanks! Trying this.
Old 01-29-2012, 03:10 PM   #4
ttr125fan09
ttr125fan09's Avatar
Drives: yaris
do what Betrivent said, if the wheels dont move than more than likely your handbrake linkages got some rust on them when you left in on through the snow
ttr125fan09 is offline   Reply With Quote
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Converting from Custom Wheels back to stock!!! daddz07 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 09-23-2010 08:45 PM
Back hurt? yarswiss Off-topic / Other Cars / Everything else Discussions 10 11-14-2008 04:39 PM
Rear wiper: EZ mod so it pulls back all the way joelitton Cosmetic Modifications (Exterior/Interior) 10 10-22-2008 10:30 AM
