#1 |
![]() Drives: VVTI 1.0 W reg Join Date: Feb 2012
Hello Yaris owners,
My dad owns a yaris 1.0 VVTI on a W reg. 131K on clock The car has a hole in the exhaust just after the last Lamba sensor, well kind of 4 holes. I have changed the sump on it last night and left the silicon to dry for over night+ new oil filter, plugs, new air filter + cleaned the maf. To change the sump, the exhaust had to be taken off and the flywheel cover plate had to be taken off + the out put lamba sensor disconnected. When i started the car the Hot engine light went on and then straight to cold after about 3 secs. This evening starting the car it felt slugish and the revs are all messed up. When i put the foot down on the floor it kind of gradually goes up till the top. When i took it for a drive it took me ages to accelerate from about 4 mph to 12 in first. Second gear was same as first. As when i put it in third the revs dropped and when i put the foot down it didn't even want to go but only kept at idling and i was loosing speed. If any one have had this problem or anything similar can you please let me know what i have to change. The car is on 131k and it never had a new clutch fitted. Thank you very much Last edited by diablo7772; 02-01-2012 at 04:14 PM. Reason: Added info |
![]() ![]() ![]() Drives: 2008 5 Door Liftback Auto Join Date: Oct 2011
Did you plug the maf back in? I know it's kinda obvious...
1999 Honda Prelude Base 5 speed (summer driver) 2008 5 Door Liftback Auto |
#3 |
Yeah the maf is plugged in and i just took all the plugs off checked them, took the maf out to have a look, took the neg off the bat and held the brake pedal for 10secs to reset ecu.
I will record a video tomorrow :( |
#4 | |
I guess you can unplug it and see if the car acts any different. Do you have anything to read OBD2 data?
#5 |
I used some WD40 and then just soft cloth. I will do that in a sec!
Yeah i have a OBD2 reader. |
#6 |
Did you spray WD-40 on the maf wires?
#7 |
Just took of the maf and had a go in the car it has helped the problem a lot but it has put it in limp mode so limited to 3.3k revs.
I will take it off and just dry it :) see if that helps unless the WD has damaged it. |
#8 |
The oil was only sprayed on the sensor pin.
#9 | |
I suppose alcohol would work too.
#10 |
what is a sensor pin...the blobby looking thing on the side of the sensor? I presume your sensor look the same as on my 1.5...
#11 |
yeah, i will have to get some electric cleaner.
Cheers |
#12 |
good luck.
| V Reg 1999 Toyota Yaris 1.0 gls semi auto | jshakey | UK | 1 | 03-08-2012 03:00 PM |
| Slow cranking on an 02 1.0 vvti Yaris | Duberry | UK | 0 | 11-01-2010 09:20 AM |
| '54 T2 Yaris 1.0 VVTi automatic clutch / gearbox / starting problem | Lettuce | UK | 0 | 09-30-2010 06:21 AM |
| 03 Yaris 1.0 VVti Engine Swap, URGENT help needed. | philwept_33 | DIY / Maintenance / Service | 1 | 05-15-2009 12:15 PM |
| x reg yaris 1.0 vvti gs (feeler) | hula hoop | Cars for Sale by private party | 0 | 12-04-2008 06:36 AM |
