Old 02-04-2012, 01:13 PM   #1
mr_miles
Drives: 2013 Yaris
Lower front skidplates
can someone take a photo or two of the bottom engine skid-plates for me? I'm missing mine and would like to know what i'm looking at before i go buy something I cant use.
Old 02-04-2012, 02:15 PM   #2
Here's a pic from under the front of my 09. I think you are talking about the two overlapping plastic panels across the front?
Name:  Yaris under front.jpg
Old 02-04-2012, 03:47 PM   #3
mr_miles
Drives: 2013 Yaris
yep! I found those online but since I'd never seen them on a car before I wasn't quite sure if they were correct. thanks a bunch!
Old 02-04-2012, 03:48 PM   #4
weedtank
I need more stars
weedtank's Avatar
Drives: Liftback
@ctscott sweet drain valve. i have them on all my cars!
weedtank is offline   Reply With Quote
Old 02-04-2012, 04:16 PM   #5
Me too. I learned about them from someone on here and since have put them on everything I own.
Old 02-04-2012, 05:13 PM   #6
cruzerbotz
Drives: 2010 5 dr LB
What's the brass fitting at the oil drain? How does it work?
Thanks,
cruzerbotz is offline   Reply With Quote
Old 02-04-2012, 06:02 PM   #7
Thanks,
It's a Fumoto oil drain valve. During an oil change you install it in place of the drain bolt. From that point forward you simply push and then turn the locking lever on the ball valve to drain the oil (without getting a drop on your hands).
http://www.fumotousa.com/faq.htm
Old 02-04-2012, 06:41 PM   #8
mr_miles
Drives: 2013 Yaris
Those are damn smart, lol. May have to invest in one!
Old 02-04-2012, 07:11 PM   #9
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
If only MI carried them...or do they?
Old 02-04-2012, 07:54 PM   #10
Garm currently doesn't, but perhaps this discussion will persuade him to.
Old 02-04-2012, 11:46 PM   #11
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
I'd buy one.
goliath1812 is offline   Reply With Quote
Old 02-05-2012, 01:37 AM   #12
Spidermandud
Spidermandud's Avatar
Drives: Black '08 Yaris Hatch S
^same
-Will-
Spidermandud is offline   Reply With Quote
Old 02-05-2012, 02:45 AM   #13
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Just be cognizant of the fact that it does stick out about 1/2" lower than the stock plug. This might not sound like much, but if you are lowered or intend to go lowered it could be something to remember as it is possible that you could rub it going over something. Might not be an issue, but thought that I would put it out there. This is my first winter where I didn't remove my dropped springs and let me tell you that with 15" wheels I am constantly skipping off my undercarriage and exhaust system as an example.
Old 02-05-2012, 03:23 PM   #14
Spidermandud
What about in combination with one of Garm's mysteriously elusive underpanel kits? (#1 on my list of things I want for the Yaris.) I haven't seen any pics of the underpanel installed on any Yari, but would you assume it would help prevent that at all?
-Will-
Old 02-05-2012, 04:36 PM   #15
Altitude
Altitude's Avatar
I've got the under panel and yes it covers the entire underside of the engine. No worries with a modified drain plug.
Old 02-05-2012, 06:34 PM   #16
Spidermandud
Sweet action.
-Will-
Old 02-05-2012, 07:19 PM   #17
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Garm, get in on this.
Old 02-06-2012, 05:05 PM   #18
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
what size is the oil drain plug on the lb ? going to buy one soon as i find out what size i need
pennyracer is offline   Reply With Quote
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
Lower Grill Replacement Idea (feeler) counterfiend Cosmetic Modifications (Exterior/Interior) 7 09-24-2009 08:40 PM
Displaying Front Plate In CA hans_fh California 42 10-22-2008 12:57 AM
