Old 02-10-2012, 03:35 PM   #1
Nightman_Cometh
Drives: 2010 Yaris. 4 door sedan.
Approaching 50,000 miles...
I drive a 4 door, 2010 yaris sedan. I bought it used back in july 2011 with 36,000 miles on it. The milage is a little high, but ive changed the oil twice now, about every 5-6,000 miles. Now that im at 50k, what is some basic maintence that I need to do? Filters, alignment, tires, tire rotatiin, etc. I dont know what the maintence history was like before I bought it, so thats why im asking. Thank you in advance and I look forward to coming to this forum often!
Ps- I also own a tacoma, any suggestions on informative forums such as this one?
Nightman_Cometh is offline   Reply With Quote
Old 02-10-2012, 05:46 PM   #2
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
My 07 sedan has almost 100,000 miles and I haven't had to do much more than oil changes. I did change the plugs around 80,000 but that was just to do something, it didn't need to be done yet. You can probably change the ATF fluid/gear oil, air filter, and you'll be all set. Keep doing your oil changes and it's a pretty hassle free car.
If you have the owners manual, it will tell you recommended maintenance. Usually oil change, filter change, inspections of fluid levels, brakes, etc.
goliath1812 is offline   Reply With Quote
Old 02-10-2012, 08:32 PM   #3
I'd probably Seafoam it, change the oil, do a tire rotation, an alignment, change the intake and cabin filters (can really just make your own cabin filter), re-lube the hinges on the doors/trunk/hood, and change your tranny lube/fluid (mt/at). Might want to change your wiper blades too (just buy the inserts from the dealership).
I changed my spark plugs around 73k, but that was just preference and not necessarily needed. Also, look under your hood to see if there is a line of coolant spray under the passenger side of the hood and report back to us.
Old 02-10-2012, 10:32 PM   #4
The Limo
Hi Nightman_Cometh
Go into the sticky thread "All Maintenance Required Based on Mileage Intervals"
Go to entry #7 (Ryu) and click on the underlined file at the top on the entry.
Fill in the info requested and this will give you Toyota Canada's maintenance schedule.
Just remember that 8000 Kilometres is equal to 5000 Miles.
Put in your info for your Tacoma and you will get a maintenance schedule for it too.
Roy
The Limo is offline   Reply With Quote
2007 Yaris S 5spd Sedan doing 300,000 miles in less than 2 1/2yrs. trini_per4mance General Yaris / Vitz Discussion 100 06-08-2022 09:54 PM
Finally, 450,000 miles on my 07 Yaris in 5 years trini_per4mance General Yaris / Vitz Discussion 36 12-07-2011 07:41 AM
2 Good Yaris Engines Under 100 Miles, Parting Out. 42 Autosports Items for Sale by private party 36 02-15-2011 10:00 AM
Man hits 1 MILLION MILES in Ford F-250... in four years!!! Kal-El Off-topic / Other Cars / Everything else Discussions 6 10-30-2010 10:19 AM
Synthetic Oil Kaotic Lazagna DIY / Maintenance / Service 122 09-20-2007 03:40 PM
