Old 02-16-2012, 07:58 PM   #1
vadr45
vadr45
vadr45's Avatar
Drives: 2009 Base 3-door
I Need Sharper Steering!
I've read all the posts about whether to buy a front strut tower bar or a rear one; whether to strengthen the front sway bar; whether to defrag the modopulator; and whether it's safe to go to warp speed without Scottie's okay. But I still don't have an answer to the question - what will sharpen my steering control in what is essentially a low-end street car.
Thanks to the previous owner, I have a full complement of upgrades to make my '09 Base 3-door into a street slut:[LIST][*]AFE Intake[*]NST Complete Pulley Set[*]Megan Racing Header[*]Custom 2.25” mid-pipe[*]Megan Racing Axle-back exhaust[*]Toyota Premium Horns w/ splitter[*]“Big Three” wiring upgrade[*]Short Shift Kit w/ bracket[*]TRD Rear Sway Bar[*]Tanabe DF210 Lowering Springs
Nonetheless, I still have a sense that the steering could be tighter, sharper, clearer. I want over-steer and I don't have it. I have read Tanabe's poem:
"Stiffen the front, induce understeer.
Stiffen the rear, induce oversteer."
But I'm not sure what I can do to achieve it. The TRD sway bar should give me what I want, but it doesn't. Will the addition of a rear strut-tower bar give me the sense that I have merely to jerk the wheel to the right and I'll achieve 90 degrees in an instant?
I recall putting a rear strut bar in my JCW MINI and noticing the enhanced steering instantly; the front strut bar did nothing but add weight. Do I need some sort of transverse bracing in the Yaris to achieve my goal? Do I need to over-inflate my tires? Do I need to lower my expectations?
I hurl myself upon your knowledge, People! What can I do?
vadr45
Alexandria, VA
2009 Black Base 3-Door Yaris
1950 Austin A70 Hampshire
vadr45 is offline   Reply With Quote
Old 02-16-2012, 08:05 PM   #2
enviri
enviri's Avatar
Drives: 2010 Yaris
you lowered your car, add struts/shocks to increase stiffness. those stock struts are SOOOFFFTT. buy some really low grip eco tires in the rear if you REALLY want oversteer lol.
you can try to add more bars, like the selection offered by GTSPEC. They offer rear spring perch bars that you can use?
Old 02-16-2012, 09:34 PM   #3
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
I would get some of Ultra Racing's rear braces.
I have the Ultra Racing 23mm rear sway bar, and it's much stiffer then the TRD one you have. This is the one I have: http://shop.microimageonline.com/Ult...R-AR23-100.htm
Also get better springs and shocks. Especially if you're still on OEM shocks, a good set of coilovers or more aggressive springs and shocks will stiffen your suspension a lot more and make it more responsive. I'm currently running on Tanabe coilovers and they have improved my handling a lot, granted they aren't the most stiffest coilovers.
But bear in mind, no matter what you do this IS a front wheel drive car, and front wheel drive cars naturally have a tendency to understeer. You'll have to stiffen the rear a lot to induce oversteer.
Black_griffin6 is offline   Reply With Quote
Old 02-17-2012, 01:13 AM   #4
No, it shouldn't. It's a step in the right direction, but not by itself. The other posts have great advice, plus:
1. Take EVERYTHING out of the back you can do without, the spare etc. Making the rear lighter will have a huge effect on your handling.
2. You didn't mention what you have for wheels and tires. Lighter wheels/sticky tires make a world of difference.
3. There are no struts in the rear of the yaris, so there is no "strut bar" back there. Knowing what suspension you have and what the parts are will serve you better, I promise.
4. If you're not going to do 1-3, take the front sway bar off. It's one way to induce more oversteer, and I know people who race with that set up.
Old 02-17-2012, 01:28 AM   #5
SAV912
Pirate Yaaaaris
SAV912's Avatar
If you want hooligan oversteer, you're in the wrong car entirely.
However, I had my first super fun/caught-off-guard lift off oversteer a few nights ago in the rain. Stupid tire shop put two replacement tires up front and put the ones with about 17K more miles on the rear. New tires ALWAYS go in the rear, regardless of drive wheels.
Needless to say, I went and had some fun with it before swapping them back around this morning. Good advice in this thread. If you're on TRD/Tanabe springs and stock shocks/struts, all the rear bracing in the world isn't going to get you where you want to be. OEM shocks are ridiculously soft. TRD Sportiva, Koni Blues (daily friendly) or Reds (not so much) should be your next step.
I'm a little baffled at what exactly it is you're after. "Sharper steering" (thread title) isn't something I exactly equate with what you're after, which is essentially lift off oversteer. Sharper steering could be mostly achieved by something as simple as unplugging the EPS fuse.
Also, listen to Garm. He doesn't own a 387 bhp track monster by happy accident.
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 02-17-2012, 01:55 AM   #6
Viperoni
Drives: 2005 Toyota Echo
Struts wouldn't neccessarily help oversteer.
Overinflating your rears will help, along with adding camber and toe out in the front.
To be honest though, if you're asking this kind of question, I'm not sure you're ready for more oversteer...
2006 Saturn Ion Redline
Old 02-17-2012, 02:05 AM   #7
SAV912
Pirate Yaaaaris
SAV912's Avatar
No, not necessarily but stiff springs and OEM struts isn't helping his case.
Georgia Bulldogs!
Old 02-17-2012, 02:50 AM   #8
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
Run wider tires in the front.
Old 02-18-2012, 01:43 PM   #9
vadr45
vadr45
vadr45's Avatar
Thank you all for your help, especially Garm and SAV912.... I've learned much, some of which I shall implement. When I do, you'll get pix.
As I distill what you've suggested, to get the sharper steering I want, I'll need a stiffer rear sway bar and stiffer shocks all around. My MINI Cooper was much the same, but the John Cooper Works package provided the rear firmness I needed and the rear strut-tower bar was pure icing: It is possible to have oversteer in a FWD car.
Sorry I don't speak your Yaris patois yet, but I've been concentrating on older cars (Morrises and Austins) for the last seven years and I'm only just getting back to modern tuning.
vadr45
Alexandria, VA
Old 02-18-2012, 02:28 PM   #10
SAV912
Pirate Yaaaaris
SAV912's Avatar
I'd love to see some of the older cars, if you have pictures. I'd trade my Yaris for a second for a good condition original Mini. Richard Hammond had a pristine example in the Top Gear India Special that aired over Christmas.
Good luck with your goals on the Yaris. If you have more questions, don't hesitate to ask. We're all here to help.
-C
Georgia Bulldogs!
Old 02-18-2012, 09:58 PM   #11
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
coilovers are really your best bet. Fully adjustable ones are the best bet, something where you can firm up the rear end as much as you can while keeping the fronts soft. MI has a great selection. Try those before spending money on braces and other things first.
I know what you mean about front wheel drive oversteer. I had a saab 9000 and the thing oversteered without warning. Fun as heck.
Colin Chapman disciple
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Is this normal with the Yaris steering lock? STC General Yaris / Vitz Discussion 13 07-06-2010 10:15 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
