Old 02-18-2012, 09:59 AM   #1
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
Show Off OILS You USE
Show off the oils you use fellow Ka-Yaris X and why? and for how long? and what improvements did you notice.
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 02-19-2012, 01:56 AM   #2
syntax
syntax's Avatar
same oil that i use before winter, nung winter kasi 5W-30 ang gamit ko, now na medo ngstart na ng tag init, same na rin like you ang ginagamit ko na oil.
Old 02-26-2012, 03:49 AM   #3
charlieXX
Corporate Slave
charlieXX's Avatar
Ano wala ng iba diyan?
Old 02-26-2012, 04:58 AM   #4
syntax
syntax's Avatar
input po sa motor oils na ginagamit nyo mga kayaris...
Old 02-26-2012, 06:20 AM   #5
Yaross
Yaross's Avatar
Drives: 2006 Yaris HB 5DR
no pictures but I use CASTROL 10W-30, summer and winter, change every 5,000 km
Yaross is offline   Reply With Quote
Old 02-26-2012, 11:15 AM   #6
dBraveheart
Drives: yaris 2008
mga kayaris... sa gearbox(manual) anong oil ginagamit niyo, ilang km bago mag change last time na mag change ako is 50,000km i used kung ano yung available na ginagamit sa shop.
dBraveheart is offline   Reply With Quote
Old 02-27-2012, 01:06 AM   #7
Yaross
Yaross's Avatar
ito po ay pananaw ko lamang...
sa manual transmission ( o gearbox), ang gamit po ng langis ay lubrication, cooling at cleaning. ang transmission po ay closed loop at sealed. wala pong gaanong panggalingan ng dumi except yung mga nauupod sa mga gears or bearing kung meron man. mababawasan lamang din po ang level ng langis kung may tagas. kung may tagas at mababa na ang level, maaring sumobra ang init at doon pwedeng magkaroon ng evaporation (very unlikely).
dahil po dyan, hindi po ako naniniwalang kailangan palitan ang langis sa gearbox. maaring mali po ako.
ang akin pong yaris ay nasa 182,000km na pero hindi ko pa pinalitan kahit minsan yung langis sa gearbox. wala rin naman po akong nararamdamang kakaiba at smooth pa rin naman sa pagkambyo.
kung marami po kayong extrang pera, i would suggest na mga 100,000km, isabay nyo na sa palit ng radiator fluid.
Old 02-28-2012, 01:03 AM   #8
charlieXX
Corporate Slave
charlieXX's Avatar
Changing at 100K is ok, 50,000 the better....sadyang may lifespan din ang oils natin sa ating gearbox or tranny, sadyang overtime eh it looses it's viscosity and thus the capability to lubricate is lessened.
Old 02-28-2012, 03:29 AM   #9
syntax
syntax's Avatar
+1 ako dito, at kung sakali man magpapalit, source out tayo ng redline..
Old 02-28-2012, 04:27 AM   #10
jonimac
jonimac's Avatar
Send a message via Yahoo to jonimac
For me... It's all our call! TOYOTA has their checklist (preventive maintenance), na post ko na yun long time ago.
jonimac is offline   Reply With Quote
Old 02-28-2012, 05:38 AM   #11
syntax
syntax's Avatar
mismo ! ! !
Old 03-04-2012, 02:47 PM   #12
ubospawis
ubospawis's Avatar
Drives: Flint Mica 2010
Totoo kaya yung sabi nung mekaniko na pag fully synthetic next 10,000km na change oil uli?
ubospawis is offline   Reply With Quote
Old 03-05-2012, 12:28 AM   #13
syntax
syntax's Avatar
actually pre' as per specs ng full synthetic oil up 15K pero para safe 10K ang advise ng mekaniko
Old 03-05-2012, 02:50 PM   #14
ubospawis
ubospawis's Avatar
salamat.
Old 03-10-2012, 03:52 AM   #15
charlieXX
Corporate Slave
charlieXX's Avatar
10K is the norm risk less, pero ako baka 7K lang para sigurado
Old 03-24-2012, 01:01 AM   #16
syntax
syntax's Avatar
@ charliexx 7k to 8k din ako usually nagpapalit ng oil, at DIY na lang natin yan hehehehehe
Old 03-24-2012, 02:53 AM   #17
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
magkano ba ang Castrol oil para sa engine hindi yung synthetic saka toyota oil filter? baka pwedeng makisuyo magpapabili na ako dyan at bayaran ko nalang pagpunta dyan (plan is April 6, sana may talyer session), magchachange oil na kc ako eh...maraming salamat...
Ciao !!!
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
xtremist is offline   Reply With Quote
Old 03-24-2012, 03:23 AM   #18
syntax
syntax's Avatar
@ xtremist, ung castrol semi synthetic ay nasa 25SR/liter at ung toyota oil filter ay nasa 15SR to 20SR depende sa shop, im sure meron din dyan sa mga gasolinahan na may naka display na castrol na logo sa katabing oil change at vulcanizing shop. advise ko lang pre' change oil ka na dyan bago ka magbyahe ulit ng malayuan.
Motion Auto Show 8/21/11 cali yaris California 2 08-20-2011 12:50 PM
Rockland Toyota's Scion Revolution 4.0 phyre76 NY / NJ/ CT / PA 70 08-11-2010 05:20 AM
ROCKLAND/SCION SUMMER SLAM 3.0 7/19/09 ROCKLAND TOYOTA NY / NJ/ CT / PA 198 08-05-2009 01:04 AM
Rockland Toyota/Scion Car show Zefoxe NY / NJ/ CT / PA 47 05-26-2009 08:16 PM
