Old 02-22-2012, 06:18 PM   #1
haha55
Drives: Yaris 2010
grounding kit in 2012
i was wondering if anyone still installing grounding wire in 2012?
i saw several HKS kits for 25$ shipped on ebay, is it good for my 2010 LB yaris? will it improve the sparks and acceleration my yaris?
suggestion and comments please
thanks alot !!
haha55 is offline   Reply With Quote
Old 02-23-2012, 04:13 AM   #2
brieghne
Drives: yaris sedan 2009
Yes it does help with the performance especially when you have hid kits installed I have to burn a ballast and two bulbs before I put one on I guess toyotas have issues with circulating electricity around. :)
brieghne is offline   Reply With Quote
Old 02-23-2012, 04:15 AM   #3
brieghne
And btw it will also give you good mileage on your car
Old 02-23-2012, 03:13 PM   #4
haha55
Drives: Yaris 2010
i have my hid's installed, so should i unplug them first before i ground wire the engine?
thanks alot for your time brieghne
Old 01-21-2013, 10:56 AM   #5
ks25
Drives: toyota yaris sedan 2010
grounding kit
yes it help keeping the car to run smoothly if there's a proper grounding for the car. also check also all ground points for any loose bolts.
ks25 is offline   Reply With Quote
Old 02-02-2013, 08:57 PM   #6
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
I did not feel this was 100% necessary, but I thought it cant hurt, so why not. So I went into my box of odds and ends wires, found some nice 10 gauge and went to town!
Well its funny, but the car is smoother. I'm sold! But I would not waste money on a goofy looking kit, when a handful of wire and some loops will run you less than $5.
Here's mine. It starts at the battery ground, then to the CPU, then right side tower(because of the available treaded hole), then a wire into the cab, to the crash bar, and one to the alt mount.
UberSilver is offline   Reply With Quote
Old 02-02-2013, 09:15 PM   #7
That's pretty cool -- if you're going to do one, it is pretty easy to make. I think the kits look a little prettier, but your DIY way is far cheaper than what we sell.
Old 02-03-2013, 04:22 PM   #8
If I can make my own for around $15 bucks I will do it. I get static shock from time to time, and my idle goes down when I roll my window down or up, plus running a (small) 400w amp. I'm sure extra grounding should help me out some how. LOL
Old 02-04-2013, 10:54 PM   #9
Got 12ft of 8 gauge wire that's heat resistant, and gasoline/oil proof, and 10 gold plated ring terminals for about $15. So gonna ground some points tomorrow.
FS: OEM Toyota Vios Turbo Kit CTScott Items for Sale by private party 24 07-31-2011 09:12 AM
Grounding Kit EjDaPogi Middle East 43 03-30-2011 07:23 AM
Blending a Kit With a Factory Bezel sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 05-02-2010 11:54 PM
GROUNDING KIT DIY? SEaton DIY / Maintenance / Service 73 10-22-2006 04:03 PM
