Old 02-28-2012, 08:23 AM   #1
yell
Drives: yaris 07
what suspension kit should i use for yaris 07
thanks for the people that are willing to give an advice :)
also if u install lowering springs. does it mean you should buy a new shocks or struts ?
just thinking :)
also what is the differences of coilover to damper kit ?
yell is offline   Reply With Quote
Old 02-28-2012, 08:37 AM   #2
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Read thru this first:
http://www.yarisworld.com/forums//showthread.php?t=8342
Determine your budget and your goals. Check out microimageonline.com and/or talk to "Cali yaris" aka Garm. He can get you what you want at the lowest price available, will even price match if you find it somewhere else cheaper.
Get back with us on your choices and we can help you further
-Derrick-
Old 02-28-2012, 08:38 AM   #3
What are you personally looking to achieve?
Drop: mild, moderate, or slammed
Ride: OEM comfort, bone jarring stiffness, or somewhere in between
Old 02-28-2012, 09:16 AM   #4
yell
Drives: yaris 07
mild or moderate ? :)
Old 02-28-2012, 10:35 AM   #5
enviri
enviri's Avatar
Drives: 2010 Yaris
You could install new struts if you want, a lot of people left the shock and strut stock. Generally, stock strut/shocks may wear out a little quicker, so keep that in mind. Aftermarket (performance) struts and shocks often add a degree of stiffness.
Old 02-28-2012, 10:42 AM   #6
yell
Drives: yaris 07
tnx for the answer :) anyway what is the difference of damper kit and coilover ? thanks :)
Old 02-28-2012, 11:32 AM   #7
ilikerice
ilikerice's Avatar
damper is usually the adjustment of the shock's Hard and Soft settings. Some coilover kits have dampening adjustments.
Just regular coil overs are just a spring that has adjustable hieght by using keys. You are just moving the spring Higher or Lower from the shock housing itself
-Derrick-
Old 02-28-2012, 11:46 AM   #8
yell
Drives: yaris 07
tnx so much ;) so what ya think should i buy to make my car look good ?
you mention height so does it means coil overs are just like lowering springs or if i buy lowering springs then i should buy coil overs too ? sorry for the stupid questions lol! but everyone is new at one point :)
Old 02-28-2012, 12:19 PM   #9
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I run Tanabe NF210 and stock struts on mine. Going to have to replace the struts though, one of the rear ones has given out on me. Ride is comfortable and handling was improved a LOT. It is a bit bumpy on poorly paved roads but I prefer that over a "squishy" feeling car. On the occasion that I drive my mom's Accord I feel like I'm on a boat.
Old 02-28-2012, 12:47 PM   #10
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
I have springs right now on an 07 sedan and the drop is pretty low for springs (~1.9in).
It is advisable to replace struts only because the new lower stiffer springs may wear out the factory spec struts more quickly. If you replace the stuts and springs together you wont have to go back under the car. But replacing the struts is not required. Lots of us are on springs with stock shocks.
If you can afford coilovers and are trying to go pretty low then I would recommend getting them. They should all be ride height and damper adjustable and they will give the most extreme handling and lowering you can get on any ride.
Or you can do what I did, buy some springs, get used to the feel and the drop and then save your money til you can get some coilovers.
GL and you may want to search. You will find a lot of great info.
Old 02-28-2012, 02:23 PM   #11
ilikerice
ilikerice's Avatar
Coilovers in the first picture, is just that.. just an example. just spring with an adjustment for hieght.
2nd pic is just a lowering spring.. nothing to adjust, so height is really determined by what the manufacture says and how much weight is in the car. ex, sound sytems... also they do not come with shocks, will have to buy separately as other here are suggesting
3rd pic is basicly what a yaris coilover is. Its usually a kit with adjustable springs and comes with shocks. these are usually more aggressive and stiffer ride, but completely adjustable for that mild look or slammed look
File Type: jpg 1264184655-ground-control-coilovers.jpg (16.5 KB, 94 views)
-Derrick-
Old 02-29-2012, 01:08 AM   #12
yell
Drives: yaris 07
tnx for the friendly advices thanks so much :) especially derrick :)
FS: OEM Toyota Vios Turbo Kit CTScott Items for Sale by private party 24 07-31-2011 09:12 AM
Blending a Kit With a Factory Bezel sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 05-02-2010 11:54 PM
ANCLA turbo kit warning! 1.5 Forced Induction Forum 11 02-26-2010 08:04 PM
Suspension Kit: Fully Adjustable or Lower Spring? JeremyG Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 04-23-2009 08:23 PM
Toyota Echo or Scion Xa/Xb for aftermarket HU receiver kit? ceboyd In Car Entertainment + Electronics (audio / video / alarm) 7 12-08-2006 02:13 PM
