Old 03-11-2012, 01:17 PM   #1
Yaris Stock Fuel System Analysis
I posted an article on the Micro Image forum, which many on here should find interesting as well, so below is a link to the article. In regards to forced induction, there is a question about at what point the fuel system needs to be upgraded. The problem is that there is no data on the capacity of the OEM fuel system, so I purchased an OEM fuel sender unit from a junkyard to use for bench testing to determine the flow rate for the OEM pump.
Here is the article, with videos of the bench testing:
http://www.microimageonline.com/foru...ystem-Analysis
Old 03-11-2012, 09:22 PM   #2
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Great info thanks!
Old 05-05-2012, 11:20 AM   #3
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
Great info!
The Spectacle is offline   Reply With Quote
Old 05-06-2012, 10:38 PM   #4
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Ditto^
flow rate, fuel pump, pressure
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 45 02-15-2025 10:30 PM
Complete Fuel System Cleaner: Is it safe? JerseyJeff84 DIY / Maintenance / Service 6 01-29-2012 03:50 AM
