Old 03-17-2012, 08:40 PM   #1
yaris4062007
Drives: 07 BB yaris / 06 Mustang Gt
How to Remove cv axle from passangerside
I am having wheel bearing replaced, i got the tie bar and control arm ball joint removed. Do i tap on the axle with nut to remove it. I hit it with plastic hammer, it doesnt move at all. ;(
yaris4062007 is offline   Reply With Quote
Old 03-17-2012, 09:53 PM   #2
Are you having trouble getting it out of the tranny or having trouble getting the hub off of it?
Old 03-17-2012, 10:32 PM   #3
yaris4062007
Hub :)
Old 03-17-2012, 11:04 PM   #4
Originally Posted by yaris4062007 View Post
Hub :)
Hmmm - When I changed the passenger axle on Crashy the hub slipping of the splines was the easy part. The service manual shows using the SST 09628-10011, which is basically a puller to remove it. With mine, I just tapped around the backside of the hub with a deadblow hammer until it slid loose.
DIY : How to remove door panels FEINT DIY / Maintenance / Service 13 11-18-2021 02:16 AM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
[DIY] To remove logotipos of the mark Sérgio Barros DIY / Maintenance / Service 6 02-23-2007 07:32 PM
